1991 1.7 TZD Estate Met.Green For Sale (E-Bay)
Re: 1991 1.7 TZD Estate Met.Green For Sale (E-Bay)
Dollywobbler wrote:It's threads like this that make me think I can't possibly scrap the Green Tiger. Sure, no turbo, but it is an increasingly rare estate!
And its a BXC legend....
..that_
Post by Mothman »
No, dont do it..........................................................
barry badger
Post by barry badger »
This is making me think again about scrapping my mot expired tzd estate, its no worse bodily than this green one and with no engine problems.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
Better the devil you know chaps, these cars are now over 20 years old so way past their designed lifespan, once the weldings done (properly) it should last another 20. And theres just not enough good ones out there now to be able to picky....
Unfortunately it may not be that straight forward. I took the descision to scrap my TGD turbo as on thorough inspection after being parked up only 2 years it was in a very bad state. The old tin worm had ate into the 'A' pillars, front inner wings, rear crossmember, boot floor, bottom of the 'B' pillars, parts off the sills, windscreen surround including top and bottom of pillars but more importantly the complete area round the bottom rear 1/4 arches, floor and the rear subframe mounts needed replacing. This area is quite a complicated structure and would have been a major task needing the fabrication of a 2 new sections.
I am a C&G qualified welder and have all the equipment but there are times when you just have to admit the shell has reached an end of life state. IMHO capturing and cutting out any rust issues at an early stage and then thoroughly treating them with preservatives is the only way to keep one of these cars on the road long term.
barry badger
My tzd needs welding to the ns A pillar, both front inner wings, one rear chassis leg and the rear silencer hanger bracket. The rear quarters are bubbly but that can be left for the moment. Other jobs needed include- os window regulator, rear radius arms, non working abs(although the tzd hatch could donate its sensors ) non working heater motor and non working speedo. Plus points are- it doesn't let in any water and despite all that's needed it drives quite well . The main problem is i'd mentally allocated its power unit to my other tzd estate that's awaiting an engine, gearbox and various hydraulic components. But now after finding out estates aren't so numerous i'm not sure what to do.
Im sure if you need an engine Barry theres a few around on here!
barry badger
It needs an engine and gearbox despite being two owners (the second owner only had it for one year) and having only done 95,000 miles. I've run this tzd for six years now so i could use its engine and gearbox with 100% confidence. Also the one needing the engine has a hiss on the hydraulics so i was going to change the rack ,fdv and regulator which between them should fix the problem.
You could always take the best of both cars to put together a solid, reliable motor, then if you decide the other shell is salvageable it can be rebuilt as time and funds allow, while also sourcing whatever mechanical parts needed for the reassembly.
It's certainly easier than a major repair job. Being able to weld is only half the battle - you also need to be able to make the repair sections you are going to fit, which can be more difficult than the welding.
Post by RxBX »
Mothman wrote:Good god, its up to 206 quid now!! Somebody wants it!!
Mothman wrote:We may all be in for a suprise then at the end of the auction.
The winning bid was an amazing £345 :shock:
Anyone off the BXC secure this one ?
Post by RxBX »
Obviously the sale (£345) didn't materialise so its been RE-ADVERTISED !
:lol:
Hmmm, MOT'd until September, but with a hole in the inner wing immediately behind the strut mount - I wonder what else got missed?
Post by RxBX »
RxBX wrote:Obviously the sale (£345) didn't materialise so its been RE-ADVERTISED !
:lol:
The second time round listing realised £215.54 !
Is anyone off the BXC forum the new/potential owner or will we see a 'round three' re-advertisement ?
:lol:
Post by RxBX »
:lol:
:lol:
He we go ROUND-THREE :?
:lol:
