If you mean the flexis to the calipers, they're quite straight forward - did them on Timex last September, and there may be a couple of pics on the blog.
make sure the bleed nipples are free before you start, as they're the most likely stumbling point. I found the joint onto the pipework a little fiddly, but not too bad - did both sides, plus disk changes in about an hour IIRC.
Dreaded octopus questions
Re: Dreaded octopus questions
