and it would be an amazing fluke if I had made a working circuit by mistake!
It's amazing !
I can't quite see from your earlier description...
I've used the ignition switched wire on the relay socket for the dim dip relay as the trigger for relay 3
but that's where it's not to drawing and why you had to add the diode - switching dip on was powering the ignition. I had something similar in my 1950 Morris Minor - I'd added a mod but didn't have thick enough wire but it seemed to survive - unknown to me the wire had melted and laid across another wire and shorted out - pressing the brake pedal turned the ignition on without the key
I assume just a simple pot mounted within reach?
Yes. The Granada has an edgewise control like the dash lighting control on the BX - even if you did put the number of seconds on the edge of the knob your finger would cover them until your finger was off again - it's a useful control but since it's not used often you don't have a chance to get used to the time settings so it's easy to 'overcorrect' when trying to get a time that's appropriate for the rate of drizzle. Hence the meter - I might design a second function for the meter such as battery voltage to make the fitting of an extra meter a more useful thing to do - just switching to 'time' when WW delay is used.
And it's an engineering compromise - if a wide range of delay times is provided (Granada is up to 30 seconds) it's harder to adjust the delay to your liking so the delay time range I've chosen is 3 to 20 seconds.
full on is all that's required round here!
With relations in Porthcawl I know what you mean
I once parked my Granada near the seafront - it had a very tiny piece of rubber missing at the
top of a door frame. We had 5 minutes of the famous Welsh 'horizontal' rain and there was a pool of water in a rear footwell
oak bracket holding the relays in place
Mahogany stained and button polished I trust
