James' BX
- x 57
Pretty sure a turbo change isn't as big as they're making out, although I've never changed one.
The water and oil leaks may be something small and easy, so it's not over yet. Obviously quite difficult if you're not technically minded and don't know what/where to look at
The arm bearings are at the rear, quite common for them to wear out at this age.
Rust...well that's just what it is....rust. Get it done by a cheap mobile guy who sounds professional on the phone, buy some Hammerite and get painting once he's finished.
Truth be told, it doesn't sound all that bad, but it's so easy to get down. Come and look at this pink 16v I've got and yours doesn't seem such a big job (although it's clearly not as cool as a pink valver!)
1983 16TRS (Sunrise red) - 1987 GTi 16v (Black) - 1989 16 Valve (Venetian red) - 1990 16 Valve (Venetian red)
- x 16
I haven't changed a turbo in situ, but 99% sure it can be done by just taking off the intercooler (3 allen bolts and 3 hex heads), removing the O/S engine mount (4 16mm nuts) and tilting the engine forwards. Not a big job. You may have mentioned elsewhere, but why does the turbo need replacing? Be wary of garages trying to rip you off...get a 2nd opinion if in any doubt.
I'm not 100% but it might need to be replaced seeing as nobody can work out what's wrong with it. The garage I use recommended I get a cheap one from another car, and transplant it.mat_fenwick wrote:why does the turbo need replacing?
I trust the garage I use, they would never cheat me out of money seeing as I'm there atleast once a week with one problem or another. If it's not me, it's my friend with the 306mat_fenwick wrote:Be wary of garages trying to rip you off...get a 2nd opinion if in any doubt.
I suppose it's not that bad but I can't see light at the end of the tunnel yet ... I owe hundreds to people and my ZX isn't selling either
I will post updates.
As has already been pointed out, there may well be *nothing* wrong with your turbo; there are various problems that may occur in other areas which would cause the turbo not to provide extra power. These include:Tourist wrote:I'm not 100% but it might need to be replaced seeing as nobody can work out what's wrong with it. The garage I use recommended I get a cheap one from another car, and transplant it.mat_fenwick wrote:why does the turbo need replacing?
1) In order to make use of the extra air forced into the engine by the turbo, it needs to inject more diesel. The manner in which demand for extra diesel is relayed to the injector pump is via a hose which connects the intercooler to a device on the injector pump. This system can fail due to either the hose splitting/perishing or being disconnected, or the device on the injector pump may suffer from a split diaphram. Both of these faults are easily checked for and cheaply repaired.
2) The air ducting which connects the turbo to the engine and inlet system may become split or dislodged. This would result in loss of turbo power, and again would be easy to diagnose and cheap to fix.
3) The wastegate on the turbo may have somehow stuck open due to the car standing, which would serve cause loss of power. If so this is quite possibly fixable by manipulation/light hammering of the actuator. Again, cheap and easy fix as to whether the linkage is seized.
4) Internal injector pump fault preventing full fuelling. Potentially costly, but still cheaper than the turbo job.
So, as you can see there are various issues here which require investigation before a turbo change is contemplated. If your garage has failed to consider these possibilities before suggesting a change of turbo, then with respect they are either ripping you off or are utterly useless. Perhaps both.
I've had a look myself, and the car has been up on a garage ramp twice now, so points 1, 2 and 3 are unlikely. To my knowledge the pipes have been checked, I think the wastegate is stuck open because the car was standing rarely used for a good few months.jonathan_dyane wrote:as you can see there are various issues here which require investigation before a turbo change is contemplated.
- BX Digit man!
Point three WAS that the wastegate is stuck open.Tourist wrote:I've had a look myself, and the car has been up on a garage ramp twice now, so points 1, 2 and 3 are unlikely. To my knowledge the pipes have been checked, I think the wastegate is stuck open because the car was standing rarely used for a good few months.jonathan_dyane wrote:as you can see there are various issues here which require investigation before a turbo change is contemplated.
As has been mentioned here, and in just about every other thread, the likelyhood of there being anything wrong with the turbo is fairly remote. Also, I very much doubt the wastegate is stuck open, as when the car is parked, the wastegate is closed. If anything, you would be getting overboost, not no-boost.
I suggest you take it to someone who can actually do some diagnosis, rather than just guesswork. (as thus far, there seems to have been guesswork and not a lot more. Done that test I mentioned yet?)
Sorry my mistake, I'm multi-tasking obviously not doing a very good job.DavidRutherford wrote:Point three WAS that the wastegate is stuck open.
Haven't had chance to try that test yet, strange as it sounds ...
I'll see if I can get the bonnet up tomorrow as I have some free time. I will try your test David if I can, thumbs up!
- x 8
Light at the end of that long tunnel
I'm sure that once sorted, you'll be unlikely to sell on as they are good fun to drive & different. Keep us all updated on progress & any issues that you come across that you need help with.
If MOT is still valid when the time comes, just insure it then take the MOT and insurance cert to the Post Office and tax it - SORN automatically cancelled. Could do it on line, but it depends on how quick your insurer updates the database.Tourist wrote:I'm a bit unclear as to how I get my box on the road again, it's SORN so I'll need to re-tax and insure.
If MOT has run out, insure it, book it in for an MOT, and take it along. Make sure the garage has got your reg number down on the booking. You might get a tug from the Police if you ping the ANPR for no tax, but as long as it's insured and you can prove you are taking it to/from an MOT, you are OK. Once MOT'd tax as above.
I NEED a BX TD.
- x 8
I presume if you're taking it for an mot, most of the issues have been sorted? or is it getting mot'd so that that it can be repaired?
The car has mot until 01/2010 so no need to worry about that. I have just bought a reconditioned alternator off eBay (fingers crossed) and I have sourced a replacement turbo (thankyou Vanny) it's just a matter of getting it. The help I'm getting on this is VERY much appreciated!
Looks like it did indeed work out in the end ...
Touch wood.
Touch wood.
