When he bought it, the specialist who had serviced it had run it on Dexron3, a common thing out here (specs state Dex2)
Trying to do the right thing, he set about trying to flush the Dex3 out by doing a series of oil changes using Dex2 but it decided to crack up anyway.
Upon removing the base plate, he found the filter was clogged and so cleaned it. This seemed to do the trick for a while but now, it loses forward drive without warning. When it does, he has to stop for 10 - 20 seconds, drop it back into drive and off it goes. It seems also to make a sound like fluid splashing around in it when this happens; anyone got any clues as to what it might be?
Initially, we thought the blocked filter may have been starving the pump and stopping for a few seconds allowed it all to settle and refill the pump. To give a start example of how unpredictable it is, he has just been on a 2000 klms+ trip with no problems, yet when he arrived back to his home town, he gets caught at a red light. Light changes, he drives off and as it rolls forward it loses its drive; counts to 20 and drives home OK and this was the first time it played up over the entire journey.
Anyone any clues, theories or suggestions?
Alan S
