I want to get all the lower wishbone suspension bushes on my car replaced, right side is clonking taking up drive and braking, pretty sure its them, will check for sure this wend.
They need to be done anyway as they're falling apart. I've had a quote of €320 from our local, says it can be a nightmare cos the pin running trhough can be seized to the subframe in which case it will cost more!
I've also heard its a straightforward job from others.
The Haynes points out a special citroen tool or making your own for pressing them in. And i've heard alignment is important.
Does anyone here have any advice they could offer? I have replacement bushes on their way.
Is it possible with a 'standard' press?
And will advance soakage with penetrating oil enable easy-ish dismatling?
Thanks
Changing Wishbone suspension bushes
maxgreenwood
'90 16TZS (m), White, 86k
citroen7
maxgreenwood
ah the reassuring voice of someone who cares
yes i will be coming up to see you if thats still ok
you said it was straight forward, i was just a bit worried when i spoke to the garage. I forgot you mentioned swapping the whole arms in which case if you can prep them thad'd be great.
Let me know whether you have any bushes as i was just about to get some sent over from the UK - i need to get that on the go this week - if you don't have any new ones i'll get them sent to you.
Looking forward to getting stuck in!
- BX Digit man!
The bolt (pin actually, but you know what I mean) is rarely a problem. With that removed the arm falls off. Burn out the old ones, beat in the new ones, shove it all back together.
First time I did them I managed both sides (all 4 bushes) in about 3hrs, which included drinking tea.
maxgreenwood
..as in the garage didn't sound too keen..ah the reassuring voice of someone who cares
Thanks David thats good to know. Did you have to be careful how they were aligned or maybe i'm being over cautious?
doesn't sound like itBurn out the old ones, beat in the new ones, shove it all back together.
