Help !!!! problems swaping the Alternator on my TZD
classic2cv
Post by classic2cv »
How do swap the Alternator on my TZD ?
Do I have get the radiator out first ?
theres not a lot of room to move things
Citroen BX
Origami in plastic and steel
^^ ^^^^bx>
Post by ken newbold »
Yes they are a tight fit aren't they!
No need to remove the rad, but it might help if you remove the rad top securing plate.
Not sure which way they come out, depends on which alternator is fitted, some will come up, other need to go down.
Good luck, and get on ebay for some new knuckles in readiness :lol:
classic2cv
all done
moving the rad doesn't help much (moves about 15mm)
but taking off the oil filter does :D
it's a tight fit but it comes out from under the car (only just)
all sorted now, i can cancel the order for the new knuckles now
\:D/ :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: \:D/
Citroen BX
^^ ^^^^bx>
ed4ferrets
Yahoo Messenger: ed4ferrets@yahoo.co.uk
Post by ed4ferrets »
Regret I only spotted this thread now...... the way to do it is remove the o/s headlight enabling you to take out the duff alternator and put in the good one 8) . I saw this done first hand by JKW so know it's ftw :wink:
'94 XM 2.1TD Break
'63 Renault Caravelle
classic2cv
ed4ferrets wrote:Regret I only spotted this thread now...... the way to do it is remove the o/s headlight enabling you to take out the duff alternator and put in the good one 8) . I saw this done first hand by JKW so know it's ftw :wink:
But you can only do that if you remove the LHM tank first (quite messy) :(
Taking off the oil filter allows you to pass the old alternator over the filter housing and out through the underside of the car between the sump and the panel under the radiator
It’s quick, easy a lot less mess all round and no skinned knuckles
\:D/ :mrgreen: :mrgreen: :mrgreen: \:D/
Citroen BX
^^ ^^^^bx>
ed4ferrets
classic2cv wrote: But you can only do that if you remove the LHM tank first (quite messy) :(
Nope, LHM tank remained in place, job was done in a jiffy too .... only hitch was that the belt was shorter than it should have been.
'94 XM 2.1TD Break
