Desperatley need fuel tank for 1990 1400 re bx
need tank or the car gets it! just replaced head lamps acc sphere windscreen washer and pump but apparently it wont go without a fuel tank! got about £50 left of budget and dont want to give up now.
- Mike E (uk)
Clairey,
I've sent a PM to you.
I maybe able to help, but does anyone know if a Diesel fuel tank is the same as a Petrol as I've never been into petrol versions !
I see you've state its been patched up, which I suppose tends to lean towards its manufactured from Steel rather than a plaggy one which the Diesels use.
Could someone confirm this ?
As to removing them there fairly easy but I suppose more difficult to re-fit !
