Hi.
My speedo had a little bit of needle wobble and has now stopped altogether.It now makes a hell of a noise which I presume is the sound of the cable revolving but not engaging.So I presume I need a new cable so to come to the crunch can they be bought at any Citroen dealers or will I need to trawl through Ebay?
Russ
BX Speedo/cable
terrymbz7034
citro-geoff
- My Cars: Xantia VSX Estate-146K-1996 (The wifes car)
BX TZD Turbo-317K- Awaiting repair/donor car(broken subframe)
BX TZD Turbo-202K-project car ongoing
BX TZD Turbo-212k-One owner car rescued from being scrapped.
2CV Charleston-101K-One owner car awaiting restoration.
ZX Memphis-185K-Wifes daily driver.
speedo cable
Try your local motor factors. Mine still list cables for the BX,or give Malcolm Lockwood a ring,he should be able to get one for you. Which end has gone,the gearbox part,or the one behind the dash? Malcolm's number is 01274 640590.Geoff
1995 ZX Memphis TD Saloon 176k
1997 XANTIA VSX ESTATE-112K(the Wife's!!)
1993 BX TZD Turbo Estate 202k waiting repairs for mot.(Just started to fix it!!)
1985 2CV 100k - waiting full restoration.
classicnut5
BX speedo cable
Thanks for all the help,I have now fitted a top end cable which has made my speedo work again.However it now clicks which I presume means the speedo head could do with doing.Am selling it anyhow and it taint that noisy to bother me.
Thanks all
Russ
Thanks all
Russ
