Leaks Cured......But
Had a strange noise from the power steering and the warning light would come on and the chracteristic pressure click was missing! Seems as though the car would pressurise at start up or under severve braking etc
So replaced the Regulator with the original which we replaced the two o-rings in! OK you would think problem solved?
Nope! Took the car for a drive and yes the light came on again but not as bad as before it seemed. Yet it still came on! Coming up the drive noticed the smell of LHM and there it was peeing out the FDV joint to the large pipe that goes to the regulator.
How is a mystery to me of that joint coming undone!
Well now the Power Steering is none existant!
So does that confirm what suspected all along? The FDV that I replaced was faulty or
