Fitting temperature gauge
I've just acquired a temperature gauge for my TRD so I don't have to do the head gasket again! I managed to find one with a green LED display to match the green display of the clock. I didn't want to upset the Lego binnacle with a traditional style gauge.
Anyway, it comes with a temperature sender which I suppose must be fixed into the thermostat housing, replacing one of the warning light sensors. Thing is, it's too small so I've either got to get an adaptor for the thread or another temp sensor entirely.
If anyone knows : where I could find either of the above or even what size the thread would be for the original sensor that would be most helpful.
Our Trim Guru
x 13
Post by DLM »
No idea on this , though I have some old Mark2 BX temp switches knocking around - which I'd imagine are the same. I'll take a measurement if non-one else knows - and I'd gladly send one if you want to experiment with tapping out an old switch.
If you want a substitute for your new temp sensor you'll need to match the specifications of that new sensor 100% (and its means of sensing) or be prepared to do some basic circuit calculation at least. Know any tame electronic hobbyists or engineers?
Thanks for reply David. I think I might have to tap an old switch as you suggest. I've also got this huge German electronic components catalogue which has adaptors for various threads, maybe something there?
Hi Todd,
I've used these before, not sure whether postage would be prohibitive. I work in temperature calibration, so I could calibrate it for you...
Thanks Mat, that does look like the stuff. Just got to get an accurate measurement now.
The sender that came with the new gauge measures as a 9mm thread ( I don't know what that would be in inches?), so I've just got to measure the BXs sender thread now..
( what are you calibrating the temp of by the way? 'Industrial applications')
Hi Todd. it's a mix of industrial calibration and equipment for other labs. It's one of those jobs that you have to explain to most people who ask what I do for a living! (We calibrate stuff to to 0.001°C so probably overkill for a BX temeprature sensor :D )
The other option (just remembered it!) which I have used before to match sensors to engines is using a local hydraulic supplier - if you can 'borrow' a sensor from your yellow one maybe, and that way you can have sample threads to match. The ones I have used seemed to have just about any thread you could think of.
