All i can remember is that David R mentioned that he regularly puts some in a tankful of diesel with no ill-affects.
My question was, does this only work with mineral oil or can you use semi or fully synthetic as well? And what is a safe amount to use in a 66 litre tank without causing loads of smoke out of the exhaust or potential damage to the fuel system?
Does the oil need to be filtered at all to remove any potential metalic particles in it? If so what do you use to filter it with?
Cheers guys
