repairing the flexible oil filler pipe
paul001
Post by paul001 »
Anyone know how I can fix the rubber hose from the oil filler to the block ? Noticed its got a slit around 1cm in it and Citroen no longer have them in stock nor can they get them
I take it you have a diesel? If so, i wasnt aware that they've gone out of stock, i'm glad i bought one a while back to replace the knackered on the turbo, so not for sale i'm afraid.
How about getting a silicone one made up?, or if you want to repair your old one, the only thing i can think of, is to get another piece of pipe which is slightly larger that can fit like a sock over the top of the old one where its damaged, or duck tape?
Whenever I need an unobtainable hose I go to the local scrapyard where he has a huge bin full of used hoses. It takes some rummaging and some careful matching but I've always found something that can be modified to fit. Therefore my BXs are part ( very small) Bimmer/ VW!
Don't know if you've got such a place near you Paul?
Our Trim Guru
x 13
Post by DLM »
I had a similar problem to this on my last-but-one TZD: on that car most of the rubber piping that could perish seemed to do so.
I cut out the middle of the pipe where it had perished and added a pushover sleeve. I didn't even attempt to remove the ends of the original pipe due to lack of space. A bit of a fiddle, but it worked in the short term (that car is now no more).
