Hose Clips Clic or Clic R ?
paul001
Post by paul001 »
Are most of the original hose clips on the BX 19 Engines either Clic or Clic R or some other kind of Jubilee style clip ? I need to remove a couple to replace the oil filler hose and would like to know which set of pliers I need to get hold of
mnde
Meteor Man
Post by mnde »
My gut instinct is that I would snip them off and fit new ones anyway.
*EDIT* which you probably were going to do already, sorry! I would prefer jubilee clip style ones anyway, saves buying special pliers.
Mark.
paul001
top one done just have to remove the starter motor
Post by paul001 »
Yep got the top one done and fitted a standard Jubilee clip have to remove the starter motor guard to get to the bottom one for now I have fitted two part pipe tape hoping it will hold
