Not an unqualified success!
SamWise
Post by SamWise »
My Hydraulic Pump belt died, so I thought I'd fit a new one. After rounding off two allen key bolts, and losing the key down into the engine bay, I decided I could do the job without removing the intercooler. Then I discovered I had the wrong size belt. Some days you're just not winning.
Turns out, they'd sold me the belt for a 1.9 GTi, not a TD. Any bets how I'll go on tonight when I have the correct one?
1966 Triumph Herald convertible with big valve twin carb Spitfire head
1973 Bedford Panorama Elite II Bus
1994 2.1TD Citroen XM
1992 Citroen AX Echo 1.4D
mike st gilles
Post by mike st gilles »
If its that sort of day best leave it til tomorrow :lol:
Mike
SamWise
Post by SamWise »
That was yesterday. Today is bound to be wonderful!
You are removing the battery first aren't you? Sorry if that sound like a daft question but I've previously spent AGES working on inaccessable parts, only to realise that by taking off and easily removabe component, the job would be a lot easier...:oops:
Also, the belt needs to be extremely tight - I use a wedge type balljoint splitter as a lever between the pump bracket and pump body to get sufficient tension to avoid slipping.
SamWise
Post by SamWise »
I haven't, but on the TD, I don't think it's really anywhere near. I will take a look though when I go back, because I'm mistrusting my memory of the engine bay! Thanks for the tip,
SamWise
Post by SamWise »
Ok, well, I'm clearly a dunderhead as regards positioning of the battery relative to the HP pump!
Anyway, didn't remove the battery, got the belt on no problem, used a big prybar to make sure it was tight, and whilst I was winning installed my new washer pump (some bodgery required - wrong connector), and made a new spraybar out of cable ties and washer hose with a few holes in, directly connected, avoiding the problem spot of the spindle. I feel like a success!
Sam do own the BUS in you signiture, if so is it up and running, as my freind sets up and runs the HASTINGS (10666 and all that) bus raley every year around MAY time, he also is in charge of HAPPY HAROLD who is a HASTINGS trolley bus with a three cylinder diesel lump in it,
if you want i will pm you his phone No.
SamWise
Post by SamWise »
Hi Malcolm
I do own it, but it's by no means roadworthy. Big jobs of the summer are to pour a slab, put up the sectional garage I got off freecycle, and then have the bus towed into the space on my lawn/drive that's no longer full of bits of sectional garage, so I can do it up. Will be at least a year!
