16v Battery bracket wanted
Anyone got one of these lying around please before I have to fabricate one? It's the bit that bolts down and holds the battery in place. I don't know if it was exclusive to the 16v but I've taken other ones off various BXs and they don't go.
As far as I know they are all the same?
x 103
They should be the same as a regular, but equally i should have a spare in the garage. Its chucking it down now, but i'll have a look tomorrow.
Thanks for replies fellas. The battery trays in both my diesels are flat with a lip under which the bracket hooks. The tray in my 16v has a 45 degree slope on its edge which seems to require a dedicated bracket. I've taken various brackets from scrapper BXs which don't fit.
If you find anything Vanny that would be greatly appreciated.
For what it's worth I have the 45 degree angle on mine too - I wonder if that's a difference on the Mk 1s?
Is this the first ever in-depth study of BX battery trays? :D Yes, it could be a Mk.1 thing!
I've investigated this further today - the fascinating world of battery trays. The TRD has a flat plastic tray and the RD has one not too disimilar to the 16v.
I thought that perhaps the battery was the problem as, though it's a Citroen item, it's specified for a CXGTI or an XM - would this make any difference as to width re fitting? Anyway, the battery is cactus so I've got a get a new one. Then I'll know whether any of the brackets I've got are suitable.
