Does anyone have, or know where I might get hold of some MK2 estate rear wings?
The D-plate 19RD estate I picked up from london a couple of months ago is looking decidedly crispy in the rear wing department, and if panels aren't available, then the car is going to be stripped and scrapped.
I've had a bit of a look at the amount of utter shit there is on my driveway, and there's no way I can justify having this car if I can't easily repair it. I know it needs a fairly serious hydraulic leak fixing, but that's the easy bit. Likewise, fitting the rear arches would be a fairly straightforward job, but if there's no panels available, then there's no point in doing anything to it.
Wanted: MK2 estate rear wings.
- DavidRutherford
- BX Digit man!
- docchevron
I've got an estate in stock at the mo mate. Front end stoved in, but I think the arse end is ok.
Cant say I've actually looked that carefully at the car, I was going to make a trailor out of it, but if the wings are good and you need them I'll cube the car and bring the wings down.
- DavidRutherford
- BX Digit man!
