On ebay! too much work for me, but perhaps a good source of spares!?
[/url][/code][/list]
1993 CITROEN BX 19 TXD AUTO RED SPARES ONLY
1996 (N) 406 LX TD - The work horse!
1999 (S) Alfa Spider
1989 (F) CX 2.5 DTR TURBO 2 Safari
- Philip Chidlow
- x 25
Hi Philip is this what your after ?Matty wrote:On ebay! too much work for me, but perhaps a good source of spares!?
http://cgi.ebay.co.uk/1993-CITROEN-BX-1 ... 0315383431
Whilst looking for the BX car link above I also came across this BUT the advertiser had got his BX 'Citroën' listed as 'Citreon'
"THIS AUCTION IS FOR A FRONT BUMPER FOR A 19993 K REG CITREON BX 19TXD"
http://cgi.ebay.co.uk/1993-K-REG-CITREO ... 0312275846
Best Regards RxBX
- DLM
- Our Trim Guru
From the listing:
TO SAVE ME ANSWERING THE SAME QUESTION OVER AND OVER THE CAR FAILED THE MOT ON THE FOLLOWING:
BOTH FRONT STRUT TOP SUSPENSION MOUNTS CORRODED - replace complete struts or strut tops
NEARSIDE HEADLIGHT LOOSE - Not difficult, surely!
OFFSIDE FRONT CONSTANT VELOCITY JOINT GAITER SPLIT - ditto
FUEL TANK LEAKING THE LEAK IS UNDER THE REAR SEAT AND APPEARS TO BE JUST THE SEAL, I THINK THE TANK HAD BEEN OVERFILLED - peculiar, possibly the rubber connecting pipes perishing (have seen this)
OFFSIDE FRONT FLUID SUSPENSION PIPE LOOSE -strut return?
OFFSIDE FRONT SUSPENSION SPHERE LEAKING - O-ring if not knackered sphere.
ADVISORY NOTICES AS FOLLOWS
NEAR SIDE A POST CORRODED BY TOP DOOR HINGE DOOR IS SECURE AT THE MOMENT
SPARE TYRE FLAT!!!
OIL LEAK DON'T KNOW WHERE FROM
FUEL PIPES CORRODED
NSF TYRE WORN ON EDGES
FRONT SUSPENSION WISHBONE MOUNTING BUSHES DETERIORATING
CAR WAS IN DAILY USE UNTIL MOT FAILURE
ENGINE IS GOOD, BODY WORK IS OK FOR YEAR CAR IS SPARES OR RESTORATION PROJECT!!
SPARE TYRE FLAT!!!
FUEL PIPES CORRODED
- docchevron
- MULLEY
I've got some spare one's in my garage if anyone is thinking of taking this one on to save it, gratis of course & you'll have to take them off the struts.
