I'm in need of a pair of front fog lights for a TZD. Does any body know where i can get hold of some, don't fancy handing nearly £100 over to GSF. or know of any way of retro fitting (without too much cutting and sticking) some fog lights.
Thanks, Dan
Fog Light (wanted)
roody262
I believe that some older Renault's used the exact same design, have a look on the bay of snot to see if there's any that'll do the job.
roody262
Ah right, thanks for the info
Does anyone know what sort of model/year uses the same design.
These are a set from a renault 5, looks very similar to me, can anyone confirm if these are a direct fit?
http://cgi.ebay.co.uk/RENAULT-5-TURBO-F ... 7C294%3A50
- x 27
350ci muppet
Erm, I don't think that the 205 lights are the same as the original BX lights...the 205 ones look slightly more square I reckon.
These may well be worth a look, alternatively a lot of aftermarket ones will fit by just removing a couple of slats.
These fitted reasonable neatly on the front of mine.
350ci muppet
http://cgi.ebay.co.uk/CITROEN-AX-SPOT-F ... 7C294%3A50
there is the light you want but as i said not cheap
Paul
Paul
roody262
