Its pretty notchy, occasionally when hot a bit jumpy, very high on the pedal and not that sharp through the gears so bearing in mind ive got about 800 miles to do this month at least I have bought a new clutch kit.
Now while I will tackle most things, I dont fancy doing this one by myself, especially as its my only taxed car at the moment and I need it.
If anyone is willing to help I can supply beer, travel to wherever etc or whatever is required. I have a pretty large bill coming tomorrow I reckon for my fuel tank issue so I cant really afford a garage at the moment. Thanks!
Who can help me with my clutch?
retrodriver
Alex
1991 BX 16 TGS 104k miles, FOR SALE
2007 Grande Punto Sporting
If my arms actually worked properly I'd do it for you. But they dont, and I'm generally a bit useless these days.
There's a few members in your neck of the woods though so hopefully someone will step forward.
I assume you'll be doing the cable at the same time, it really pays to.
retrodriver
pitman
Me too thinks it's worth to check cable and maybe the lever, too.
You may not have the right hills around but a clutch is definetely worn if you can't go up a hill anymore as before.
There are quite a few other problems related to the clutch that are worth checking before.
BX Leader 19 Diesel - 1986
citro-geoff
- My Cars: Xantia VSX Estate-146K-1996 (The wifes car)
BX TZD Turbo-317K- Awaiting repair/donor car(broken subframe)
BX TZD Turbo-202K-project car ongoing
BX TZD Turbo-212k-One owner car rescued from being scrapped.
2CV Charleston-101K-One owner car awaiting restoration.
ZX Memphis-185K-Wifes daily driver.
BX Clutch
I've offered my services to Alex and hopefully will do the job on saturday as he is only about an hour away from me.
1995 ZX Memphis TD Saloon 176k
1997 XANTIA VSX ESTATE-112K(the Wife's!!)
1993 BX TZD Turbo Estate 202k waiting repairs for mot.(Just started to fix it!!)
1985 2CV 100k - waiting full restoration.
retrodriver
Im pretty sure the clutch will be the original, and at 101k miles it will be just my luck it goes pop on holiday with mates, plus its super high and my MOT bloke said get it done just to make sure.
Yep im off down to Geoffs, thanks again!
By the way, ive never known a car club/forum be so generous in terms of time, knowledge and of course parts!
Alex
rhv100
retrodriver
