High pressure pipes wanted
jim
Post by jim »
Hi people,
I need the set of four long high pressure pipes, that run from front to rear, along the near side of the car. My car is a BX DTR estate, F reg.
Regards jim
Regards Jim
Post by ken newbold »
If you can't get any anywhere else, I'll see what I can do. I'm not sure if they're still available or not.
I'm going to Eastern Europe tomorrow so I'll check you out when I get back and if all else fails, I'll post them somehow. :?
Have you tried Edwards & Sons Billericay?
Philip Chidlow wrote:Have you tried Edwards & Sons Billericay?
Aren't these second hand bits? I wouldn't chance reusing these pipes having done a replacement job (& mine are plastic coated)!
Have you thought about the copper solution Jim, if the steels are elusive at the stealers?
Edwards do new bits too occasionally - but they are IME and more importantly, a good source of information for finding new parts generally. Worth a try.
i have a stash of new front to rear and other pipes as i have bought some cit/pug job lots in the past, some have lost there part No. lables though, so it might be a case of break out the tape mesure
i have a stash of new front to rear and other pipes as i have bought some cit/pug job lots of all sorts of bits N bobs in the past, some have lost there part No. lables though, so it might be a case of break out the tape mesure
