Just noticed this item on ebay this morning, might possibly of use to someone, just to save from the 205 fraternity.
Being a late registration it is likely to be a three rom ECU and also have a CAT.
See item number 290319357770
Better be quick though, as the auction has not got long to run.
citroen BX 16v for sale on ebay, better be quick.....
Kevin B
- x 27
Kevin B
With the number plate clearly on display for all to see, some of the more knowledgable members of this forum could easily confirm its history (good or bad) via the DVLA. After all if you were selling a dodgy motor on ebay would you display its number plate ?
Its more likely this vehicle has being sent for scrapping, and the scrappy knows its true value exceeds its weight in scrap. Hence has butchered off the steering lock to get the engine started, so in his mind to increase its value.
I personally would not have a problem buying it myself if it was not so far away.
- x 27
Fair enough. Likely an engine donor BX though, unfortunately... This could be the very same 16v that was so temptingly advertised (and sold) on eBay three or four years ago. I went for well over £1,000 then I think. It was in Shropshire IIRC. There's some speculation on the 16v forum.
