hi folks,
i need a drivers seat for the bx estate i have just bought. the present seat is black/grey and appears beyond repair as the frame is bent. i am in bushey near watford so hopefully there is one local to me.
regards
nick
bx drivers seat needed
- DLM
- Our Trim Guru
Just a point, Nick, unless you're not fussy, it'll help to know what the model is as trims vary. I suspect it'll either be a TX (solid black coloured seat cover with diagonal stripes) or TZ (black and grey pattern on seat & seat back, bolsters in black).
These two patterns are basically the same seat frame, but with different covers, shaped foam cushions and bolstering patterns.
I don't have any completely assembled seats here, but others probably will.
- Jaba
- My Cars: BX GTi, C3 Auto
- x 83
It is possible to dismantle the seat and straighten it up.
See my earlier posting : http://www.bxclub.co.uk/forum/viewtopic.php?t=10110
- DLM
- Our Trim Guru
Have done this before now by substitution of a complete donor frame into a TXD seat from a much earlier BX's front seat. It's a fiddly, time-consuming job, though hardly rocket science, but it worked well. The seat back frames are identical on BXs apart from possibly the 16v.
The main drawbacks are:
(i) extracting the locking clips either end of the seat tube for rake adjustment carefully enough that they can be re-used.
(ii) removing/replacing the seat cushion and cover without causing damage - a bit of destapling/declipping and restapling/reclipping is required, and the plastic seat trim and screws are a bit prone to damage.
(iii) Keeping everything clean during the operation!
Another short-term workaround is to swap over driver and passenger seat backs, but only if the passenger seat gets minimal use.
I have at least some spare TZD seat backs, as I knocked down a couple of front seats for easier storage, but I'm down on the South coast
- Brian King
- BX 4x4 Owner. Brave.
I have a whole interior in good condition for the same asking price as the central locking plip advertised here recently but I'm not paying for the postage!
Colour: Black & White television interference
