Original O-rings 96995632 - like sphere type but smaller
Our Trim Guru
x 13
Post by DLM »
Have had some of these knocking around for a while - can anyone ID them from Citroen part number 96995632 ? This was on an envelope they were being stored in.
They're like sphere O-rings (square cross-section) and appear to be for hydraulic usage but are slightly smaller in diameter than the sphere o-ring.
Will pop a measurement on later if it helps.
mountainmanUK
Post by mountainmanUK »
Hi David!
According to the Cit website, what you have there is...
96 995 632 PISTON SEAL REAR BRAKE CALIPER NFP
There ya go :wink:
Our Trim Guru
x 13
Post by DLM »
Aha! (as Alan Partridge might say). Many thanks - knew it had to be something fairly obvious.....
Might try another later.
