Who's there? (persistant knock)
Boxwolf
Post by Boxwolf »
While driving, there is a knock from the front wheels; this is usually when going over bumps. A friend told me it sounds like a rubber damper has gone on one of the rods that holds the wheels in place or something. I don't know much about this but also the car had an advisory on the MOT for the lower suspension ball joint, so could it be that?
1992 BX TXD Turbo
Yes, or the other most likely suspect is the droplinks.
Is there any play with the steering, or any change of direction when coming on and off the throttle? Could be wishbone bush, but as suggested most likely droplink. Easy fix luckily.
Boxwolf
Post by Boxwolf »
Okay, thanks guys... so how would I go about fixing the droplink?
1992 BX TXD Turbo
Boxwolf wrote:Okay, thanks guys... so how would I go about fixing the droplink?
By replacing it. :wink:
(The pictures on the following thread show how it's done).
But given how you had an advisory on the ball joint, and it's *unlikely* to have improved in the meantime, I'd check that first!
Boxwolf
Post by Boxwolf »
This may be a thick question but how would I check it?
1992 BX TXD Turbo
You need to see if there is any play in the balljoint. If there is detectable movement, then it needs replacing.
Boxwolf
Post by Boxwolf »
But how would I check that? is it a "take the wheel off" job or can it be done with the car on the ground?
1992 BX TXD Turbo
IMO, checking it on the ground won't show much - the weight of the car may hide play that you would see when the suspension is unloaded. Get a pry bar, and see whether you can detect any play in the joint by trying to lever it apart.
Boxwolf
Post by Boxwolf »
I'm afraid your estimate of my mechanical knowledge is a little bit off the actual value. In other words "whats a pry bar? where do I put it? does the car have to be jacked up? does it need the wheel off it? Is there a step by step guide anywhere?"
1992 BX TXD Turbo
If you can't work out how to insert a pry bar into a ball joint to check for play, then I suggest you get someone else to check it for you, as that's a very basic thing to be doing.
If your mechanical knowledge is that limited then please don't start fiddling with suspension or brakes. Really. You're running the very real risk of doing something really dangerous, and putting other people at risk.
