Suspension & steering
Part number Qty Description Application RP No> >RP No RRP
96070144 1 LHF wishbone 208.63 39.67
96070145 1 RHF wishbone 208.63 38.35
95611436 1 Wishbone spindle 23.87 9.61
95637690 4 Front wishbone front bush 12.15ea 23.61
96070064 4 Front wishbone rear bush 16.36ea 30.64
95615973 1 LHF hub carrier/swivel ABS 357.08 155.68
370142 1 Rear hub & bearing Non-ABS 108.48 57.60
95035532 1 Rear hub & bearing ABS 116.24 46.40
95571695 1 LHR suspension arm Non-ABS 283.29 128.59
95637694 1 Front anti-roll bar 1.6 petrol, 1.7D, 1.9D 55.33 35.99
95597955 3 Front anti-roll bar link 3857 66.36ea 83.25
95630094 1 Steering flexible coupling PAS 21.99 13.98
95631286 1 Steering flexible coupling Non-PAS 17.74 8.65
95495440 1 Inner steering ball joint 50.35 21.00
405825 3 Inner steering joint lock washer 1.38ea 2.07
95604346 1 Steering rack gaiter LH? 22.57 13.50
95496072 1 Steering rack gaiter RH? 10.73 6.66
406621 1 Steering rack protector RH? 4.96 2.54
95496583 1 Road wheel 5x14, non-vented 61.68 28.09
540163 1 Road wheel 5x14, vented 32.41 22.68
96155310 1 Road wheel 5.5x14, vented (fits Xantia also) 38.65 17.60
Hydraulics
527207 1 Cylinder stop plate 7.25 3.70
527209 4 Pushrod retaining clip 1.13ea 3.18
527210 4 Stop plate retaining clip 1.89ea 3.86
95568737 1 Rear suspension pushrod 42.51 17.55
529122 1 Front height corrector 104.54 46.83
4048G2 1 Steering pinion valve PAS 338.37 184.94
96151895 1 Security valve 73.50 28.36
402401 1 Flow divider PAS 632.55 111.33
95588686 1 Pressure regulator 1.6 petrol, diesel non PAS 154.54 91.09
5491085 1 LHM reservoir 99.84 42.01
527108 1 LHM reservoir level sensor 9.31 6.98
95488446 1 LHM reservoir cap 5.53 2.67
5508681 1 LHM reservoir filter 18.45 11.07
527106 2 LHM reservoir filter 7.39ea 9.50
5461317 1 LHM reservoir retainer 13.08 1.19
95564253 2 Front sphere 1.4 petrol 55.42ea 70.48
95630610 2 Front sphere 1.7TD saloon, 4x4; GTi >3877 55.42ea 52.18
96024568 4 Front sphere 1.7TD estate; GTi RP 3878> 52.50ea 140.96
96087641 4 Front sphere 16V, ABS 52.49ea 140.96
96024566 2 Rear sphere Estate RP 3878>, except 1.7TD 52.49ea 54.74
96087642 2 Rear sphere 16V, ABS 52.49ea 70.48
95622818 8 Front strut return pipe 9.03ea 36.94
96127591 9 Strut return pipe clip 3.84ea 16.27
5437354 1 Accumulator sphere 81.41 48.85
95589236 1 Hydraulic pump Petrol except 16V 2411.32 211.58
520006 3 Hydraulic pump belt Early 1.4 petrol 9.33ea 11.34
91536298 3 Hydraulic pump belt Diesel except 6+2; 16V >4223 9.36ea 11.33
96030258 1 Return “octopus” 39.16 24.73
95567454 1 Main reservoir return hose Early 1.4 petrol 57.56 26.71
95603420 1 Main reservoir return hose Diesel & PAS 5167 62.99 32.91
96119048 1 Main reservoir return hose PAS 5168 45.64 25.42
95624231 1 Supply hose, reservoir to pump Petrol & PAS, except 16V 40.53 13.09
96093539 2 Pipe to brake valve RHD 3.88ea 5.45
96093540 2 Pipe to brake valve RHD 4.00ea 4.92
96093541 2 Pipe to brake valve RHD 3.79ea 4.63
96093542 2 Pipe to brake valve RHD 4.35ea 5.38
95596539 2 LHF brake pipe Non-ABS 10.32ea 10.00
95596540 2 RHF brake pipe Non-ABS 10.64ea 10.75
96093534 3 Front to rear brake pipe Non-ABS 20.51ea 27.38
96119932 3 Front to rear suspension pipe 20.61ea 26.24
96093536 1 Brake pipe to security valve 4.51 2.89
96093538 1 Pipe to front brake “T” connector 4.07 2.45
96033164 1 Pipe, flow divider to strg pinion Including 1.7TD 4102 12.18 6.38
40207A 1 Pipe set, pinion valve to PAS ram PAS, except 4x4 16.01 5.05
95592923 1 Pipe, regulator to pump Early 1.4 petrol 23.19 9.85
96028927 1 Pipe, regulator to pump Late 1.4 petrol 7.92 1.93
96020901 1 Pipe, regulator to pump 1.6 petrol, non-PAS 22.90 9.90
95576508 1 Pipe, regulator to security valve Early 1.4 petrol 22.97 4.55
95605517 1 Pipe, regulator to security valve Except 1.4 petrol 4101 20.43 8.94
95597151 1 Pipe, regulator to security valve Auto, non-PAS 4101 8.94 5.48
95567431 2 Pipe, security valve to front h/c 9.45ea 8.43
95595683 2 Pipe, security valve to rear h/c 18.08ea 15.87
95595685 2 Pipe, rear h/c to 3-way union 7.84ea 7.11
95595682 2 LHR suspension pipe 8.27ea 7.81
96117586 3 RHF suspension pipe 8.90ea 11.27
95603737 1 LHF suspension pipe 16.99 7.77
95567435 1 Pipe, “T” to LHF suspension pipe 9.04 4.17
95596564 1 Pipe, pump to flow divider Diesel & PAS 22.00 11.29
95603177 2 Pipe, pump to flow divider 1.6 petrol >RP 4101, 1.9 petrol except 16V 22.34ea 19.78
96016907 1 Pipe, pump to flow divider 16V & PAS 4223 19.54 6.08
96034027 1 Pipe, pump to flow divider 16V & PAS 4224 10.47 3.60
95596576 1 Pipe, regulator to flow divider PAS, except 16V 20.23 10.99
95596578 1 Pipe, regulator to security valve PAS 4101 13.18 5.70
95597151 1 Pipe, regulator to security valve Auto 4101 8.94 5.48
Brakes
4745L2 2 Handbrake cable 27.10ea 34.72
96011524 0 LH handbrake cable guide 4.85 SOLD
96118522 0 RH handbrake cable guide Except 4x4 10.64 SOLD
96035565 1 RHF brake disc deflector 7.03 3.20
95651079 1 Rear brake caliper 393.77 46.71
91537913 1 Rear ABS sensor Except 4x4 175.94 55.49
95661746 1 Front brake disc kit Non-vented 80.62 29.10
95624484 2 Front brake pad set 45.79ea 36.59
95661849 1 Rear brake disc kit 69.97 31.75
95650890 2 Rear brake pad set 40.20ea 30.09
95632790 0 Front flexible brake hose ABS 20.77ea SOLD
Gearbox, clutch & transmission
95591608 38 Clutch/brake pedal return spring RHD 1.35ea 11.78
95612702 2 Clutch cable Early 1.4 petrol 23.55ea 34.14
96081712 1 Clutch cable 1.6 & 1.9 petrol, 1.7 & 1.9D 34.19 20.56
96081710 2 Clutch cable 16V & 1.7TD 28.29ea 29.82
2050W2 2 Clutch kit 1.6 & 1.9 petrol, except 16V &4x4 4529 225.40ea 125.54
96134964 1 Clutch relay lever Except 16V & TD 4529? 17.23 9.22
95567189 9 Clutch relay lever pushrod Except 16V & TD 4529? 1.14ea 5.13
211810 3 Clutch relay lever adjuster screw Except 16V & TD 4529? 4.66ea 1.17
2004A1 1 Clutch cover 16V, 1.7TD, 4x4 petrol 87.56 15.26
2050W6 1 Clutch kit Diesel except 1.7TD 231.47 60.00
205208 1 Clutch kit 1.7TD 261.92 76.44
95596491 ??? Long gear rod, from lever (upper) Early 1.4 petrol
95495342 1 Short gear rod (transverse) Early 1.4 petrol 14.22 4.47
95569317 2 Relay lever Early 1.4 petrol 42.45ea 0.00
95495340 1 Long gear rod, from lever (lower) Early 1.4 petrol 35.18 16.22
96006362 1 Short gear rod (transverse) Late 1.4 petrol 7.87 3.37
95636577 1 Long gear rod (transverse) Late 1.4 petrol 17.19 6.75
95635511 1 Long gear rod, from lever (upper) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4529 62.66 17.57
95495557 1 Short gear rod (transverse) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4529 13.75 4.82
96049753 2 Long gear rod (transverse) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4530 12.77ea 10.74
2454A4 1 Auto gear cable ball end 5.14 2.28
210948 1 Transfer casing gasket, large Early 1.4 petrol 12.57 5.55
210946 1 Transfer casing gasket, small Early 1.4 petrol 4.92 2.23
210912 1 Input shaft guide bush & seal Early 1.4 petrol 17.28 5.88
230214 1 Splined drive tube Early 1.4 petrol 15.91 6.93
211736 1 Clutch fork Early 1.4 petrol 14.15 9.60
212037 5 Clutch fork pushrod Early 1.4 petrol .79ea 1.45
329351 2 Outer driveshaft gaiter Various 18.55ea 11.38
328774 1 Inner driveshaft gaiter Various 23.39 8.47
329383 4 Outer driveshaft gaiter Various 20.41 34.20
329391 0 Outer driveshaft gaiter Various (ABS, GTi, etc) 32.71ea SOLD
329396 2 Outer driveshaft gaiter Solid plastic 23.21ea 22.00
95638113 1 Upper speedo cable Mk1 (for ED-Veglia, will also fit Jaeger) 19.68 5.49
75513020 0 Upper speedo cable Mk1 (Jaeger only;shorter cable) GT 19.34 SOLD
Engine & fuel system
95575329 1 Carburettor Early 1.4 petrol 194.48 0.00
95619435 1 Choke cable 18.39 8.49
95610428 1 Fuel tank pick-up & return unit Petrol 3738 15.00 6.89
95610427 1 Fuel tank pick-up & return unit Diesel 3738 23.85 8.97
156389 1 Fuel pulsation buffer Petrol injection 40.46 22.10
95594177 1 Metal fuel supply pipe Except petrol injection 9.47 6.57
95594178 1 Metal fuel return pipe 7.30 5.07
81640 1 Cambelt 16V 29.91 12.79
94957 3 Exhaust valve 1.6 petrol RP 4158>, 1.9 carb 24.35ea 45.36
94887 2 Inlet valve 1.6 petrol RP 4158>, 1.9 carb 14.41ea 13.46
51414 1 Crankshaft oilseal, flywheel end Early 1.4 petrol 17.92 0.00
51415 1 Crankshaft oilseal, timing end Early 1.4 petrol 6.60 4.59
118E5 2 Main bearing thrust washer 2.40 Early 1.4 petrol 4.00ea 2.48
118E9 3 Main bearing thrust washer 2.55 Early 1.4 petrol 15.80ea 30.36
118F0 2 Main bearing thrust washer 2.60 Early 1.4 petrol 15.99ea 20.48
209A6 1 Cylinder head gasket, std 1.20 Early 1.4 petrol 22.89 0.00
209A7 1 Cylinder head gasket, rep 1.40 Early 1.4 petrol 30.06 15.41
24939 1 Rocker cover gasket Early 1.4 petrol 5.96 2.93
25818 1 Oil filler cap Early 1.4 petrol, 1.6 & 1.9 petrol 9.97 10.78
95588076 1 Oil breather pipe Early 1.4 petrol 13.84 4.90
24974 1 Rocker cover gasket 16V 27.74 15.22
95639404 1 Air intake pipe, to filter casing? 1.7TD 21.20 7.43
91536683 1 Air filter casing, with element Various models, petrol & diesel 43.87 30.25
96059366 1 Air filter casing bracket Various models, petrol & diesel 13.80 6.78
96087419 1 Air hose, filter to throttle housing Petrol 1.9 injection, except 16V 4924 19.88 14.91
96015959 1 Air intake hose to filter Petrol 1.6 &1.9 injection, except 16V, 1.9D RP 3796> 34.65 0.00
570525 1 Alternator 1.6 & 1.9 petrol; 1.9D >RP 4921 148.36 75.00
91515530 1 Alternator Early 1.4 petrol 97.67 59.80
5705JN 1 Alternator Late 1.4 petrol, 5/88>9/91 91.98 65.00
5705JS 1 Alternator Late 1.4 petrol, 9/91> 122.82 110.50
5802EQ 1 Starter motor Diesel, CL5 167.40 104.00
580245 1 Starter motor Early 1.4 petrol 225.40 55.02
95495358 1 Aux belt tension roller Early 1.4 petrol 82.43 38.65
95588568 4 Front exhaust pipe Early 1.4 petrol 4195 59.19ea 95.28
96012198 2 Exhaust down pipe Late 1.4 petrol 4196 103.97ea 62.14
96076275 1 Front exhaust pipe 1.6 & 1.9 carburettor 107.82 41.22
95634351 1 Transverse silencer Flange fittings (e.g. TD, GTi) 78.19 26.33
96048419 1 Rear silencer Estate, 1.7TD & injection 77.27 35.93
30446 1 Sump gasket Early 1.4 petrol 9.90 4.51
95638829 8 Oil filter Early 1.4 petrol 11.27 20.48
113152 1 Oil level sensor 1.6 & 1.9 petrol 35.35 13.20
117824 1 Oil breather/filler neck 1.6 & 1.9 petrol, 16V 14.52 7.56
184472 1 RH engine mounting Late 1.4 petrol 26.21 6.92
1807P0 1 Lower rear engine mount, cast Late 1.4 petrol 30.09 52.44
120169 1 Water pump Early 1.4 petrol 86.94 27.13
120681 1 Water pump gasket Early 1.4 petrol .98 .36
95593786 1 Radiator fan cowling Except 16V & 1.7TD 43.61 0.00
95634724 1 Radiator fan shroud Petrol except 16V 10.72 5.64
95633842 3 Upper radiator panel Diesel 3796? 6.73ea 13.23
95601742 2 Radiator fan shroud Diesel except 1.7TD 27.45ea 26.74
95635181 1 Radiator 1.7TD 267.21 137.38
95639271 1 Lower radiator panel 1.7TD 6.31 3.95
95593786 1 Radiator fan panel Petrol & diesel, GATE 43.61 0.00
95601821 1 Radiator fan panel Petrol & diesel, AOP 52.40 22.38
95591751 4 Lower fan panel bracket 2 fan system (e.g. 1.7TD, 16V) 6.75ea 14.52
95566628 1 Top radiator hose Early 1.4 petrol 52.16 24.51
95610901 1 Metal coolant pipe, back of head 1.6 & 1.9 petrol, except 16V 18.17 8.47
96170006 1 Top radiator hose 1.9D, 6+2 pump? (remote filter) 48.81 22.37
1307J5 2 Hose, exchanger to thermostat 1.9D manual (remote fuel filter) 8.37ea 10.64
1307W2 1 Hose, to metal pipe back of head 1.9D (remote fuel filter) 40.93 24.06
95587675 1 Top radiator hose 1.7D, 1.9D (remote fuel filter) 3796 25.99 22.41
96162612 1 Metal coolant pipe, back of head 1.7D, 1.9D (remote fuel filter) 3796 10.79 5.39
95638396 0 Top radiator hose 1.7TD 23.70 SOLD
96164164 1 Bottom radiator hose 1.7TD 5638 38.89 15.86
190413 1 Fuel filter head, Roto Diesel Diesel (remote fuel filter) 73.02 50.51
95595188 1 Fuel filter unit, Purflux Diesel (remote fuel filter) 118.37 61.70
594029 2 Distributor cap & rotor, Ducellier Early 1.4 petrol, 1.6 petrol etc 24.67ea 37.68
594031 2 Distributor cap & rotor, Ducellier Early 1.4 petrol, 1.6 petrol etc 24.64ea 33.98
594047 1 Distributor cap & rotor, Bosch Late 1.4 petrol 41.48 24.76
594548 4 Ignition module Petrol, inc 16V 73.90ea 139.68
97533275 1 Ignition lead set Early 1.4 petrol 52.44 20.37
5967N9 1 Ignition lead set Late 1.4 petrol 43.86 21.53
597043 2 Ignition coil Late 1.4 petrol, etc 57.78ea 57.92
95636601 2 Ignition lead set Early 1.6 petrol 36.81ea 36.68
95659598 1 Ignition lead set Late 1.6 petrol 59.49 28.57
597042 0 Ignition coil 16V 48.06 SOLD
9401445798 1 Air filter foam Early 1.4 petrol 4.16 1.60
9401906148 10 Diesel fuel filter, Roto Diesel Remote fuel filter 8.35ea 64.79
95608910 8 Diesel fuel filter, Purflux Remote fuel filter 17.30ea 58.64
SRV503 8 Petrol fuel filter Carburettor 4.66ea 17.04
CITBP6EFS 17 NGK spark plug Early 1.4 petrol, 1.6 & 1.9 petrol > 7/87 2.87ea 13.26
CITBCP6ES 38 NGK spark plug Late 1.4 petrol, 1.6 & 1.9 petrol 8/87> except cat & GTi 2.87ea 26.22
CITBCPR6ES 11 NGK spark plug 1.6 & 1.9 petrol with cat except GTi 3.99ea 15.25
CITBCP7ES 4 NGK spark plug GTi 8V except cat 2.87ea 3.52
CITBCPR7ES 12 NGK spark plug GTi 8V & 16V with cat 3.86ea 12.00
CITBCP7ET 14 NGK spark plug 16V except cat 6.57ea 30.80
Body mechanisms
95562445 2 RH external door handle 12.86ea 7.58
95562446 1 LH external door handle 17.42 4.76
95573650 1 LHF door lock mechanism For central locking 49.92 19.95
95573657 1 LHR door lock mechanism For central locking 53.31 19.11
95573658 1 RHR door lock mechanism For central locking 37.57 19.34
95564093 1 Tailgate catch Saloon without central locking 36.48 16.43
95566740 1 Tailgate catch Saloon with central locking 59.22 30.53
95564118 1 Tailgate lock button Without central locking 11.98 8.35
95610886 1 Tailgate striker Estate 3.31 1.61
95612096 1 Bonnet safety hook 13.07 9.29
75530712 1 Bonnet lock 33.28 15.19
95635160 1 Bonnet release cable 9.77 8.30
95608415 1 Bonnet striker pin Plastic bonnet 6.86 3.49
95564275XX ??? Rear seat back release handle
95570569 1 LHR seat back lock 23.86 12.53
95570570 1 RHR seat back lock 23.86 8.18
95649395 1 LHF electric window mechanism CIM 132.49 37.91
95649397 1 LHR electric window mechanism CIM 94.37 31.83
Body electrical
95494828 1 Front wiper motor, Marchal 167.76 108.63
95623204 0 Front wiper motor, Bosch 96.57 SOLD
95623205 1 Front wiper mechanism, Bosch 108.86 33.69
95589142 3 Front wiper arm 32.46ea 31.89
95495714 1 Windscreen washer spray bar 11.66 5.31
95633058 1 Front screen washer bottle 32.79 4.65
95633057 1 Rear screen washer bottle 12.77 6.18
643466 1 Windscreen washer pump 11.63 7.06
97533660 1 Wiper stalk 48.79 17.94
95618753 1 Dashboard fuel gauge, Veglia Except GTi 47.99 0.00
644590 1 Heater fan resistor 3710 45.38 25.18
6155J9 1 Digital clock 92.67 37.50
96070197 0 Ignition/door lock set Cross cut key 97.08 SOLD
95662479 1 Ignition/door lock set Flat key 5956 62.70 43.93
96008430TR 1 Rear wash/wipe switch Saloon 4131 19.42 9.73
6239G4 1 Hazard flasher switch 32.06 13.15
97523100 1 Front foglamp switch 13.68 9.46
95634839TR 1 Heated rear screen switch 4131 28.78 13.56
95634839FXX 1 Heated rear screen switch 18.08 11.54
96085588 1 Battery positive cable 1.6 petrol & 1.9 GTi 39.54 16.85
96091774 1 Battery positive cable 19TRS; diesel RP 4983> 20.24 11.84
96030080 1 Battery positive cable Late 1.4 petrol 18.28 6.09
95584782 1 Battery negative cable 19TRS, 1.4 petrol 8.97 8.73
95569042 1 Battery negative cable 1.6 petrol, 1.9 GTi, diesel 22.29 10.53
95588298FYD 1 Hazard flasher switch, grey Mk1 24.34 14.83
95588305FYD 1 Light switch, grey Mk1 12.57 9.48
Body structure
95630375 1 RH headlamp mounting panel 17.21 6.47
95605366 1 Bonnet seal, above headlamp 4.28 .92
95612062 1 LHR wing Mk2 saloon 177.26 60.97
95612063 1 RHR wing Mk2 saloon 177.26 82.79
95568456 2 Fuel filler flap 40.11ea 39.20
95631758 1 Front subframe Early 1.4 petrol 249.64 161.68
95563211 2 LHF wing Mk1 135.10ea 95.92
95563210 2 RHF wing Mk1 141.93ea 104.50
95619149 1 Front bumper Mk1 167.28 71.24
95565244XA 1 Front bumper grille Mk1 62.95 18.29
95587856 2 Rear panel assembly Saloon 138.63ea 90.34
95633140 1 Rear subframe Except 4x4 408.87 162.35
95563310 2 Front bulkhead cowl top 52.20ea 66.90
95631043 2 Front bumper side bracket 10.79ea 10.72
95645962 1 LHF inner arch panel 167.47 121.42
95645961 1 RHF inner arch panel 104.49 98.41
95615414 4 LHF inner wing side panel 51.25ea 75.40
95615413 2 RHF inner wing side panel 43.65ea 35.00
95595027 1 LHF chassis leg 59.89 67.15
95595026 1 RHF chassis leg 111.84 67.15
95560885 1 LHF chassis leg end bracket 7.60 4.57
95560884 1 RHF chassis leg end bracket 5.50 2.58
95575083 1 Battery support bracket Except early 1.4 petrol 31.31 12.26
95587858 1 LHR lamp panel Saloon 41.20 15.15
95617022 1 RHR inner wheel arch assembly Saloon 163.66 73.70
95587860 1 LHR upper inner wheel arch Saloon 93.86 57.48
95567708 1 LHR floor leg Estate 22.58 7.87
95616854 1 Rear crossmember Estate 116.46 50.00
95616852 1 LHR towing eye Estate 31.11 16.78
95616853 1 RHR towing eye Estate 34.64 16.78
95615179 3 Lower front crossmember 4071 51.54ea 48.03
95616626 2 Locking plate, front panel 15.35ea 23.02
Body trims & mouldings
95619577 1 LHR wheelarch protector Estate 24.31 11.56
95619579 1 LHR wheelarch protector Saloon 26.23 9.82
95604802 2 Rear wing upright seam trim Saloon 2.75ea 2.66
95570784TR 1 Front seat backrest moulding 24.84 12.86
95661828 0 LHF bumper duct/cover 16V Phase 2 47.26 SOLD
95595330 1 Wheel trim Mk1 RS, etc 20.36 14.19
95632315TL 1 RHF door capping, grey 15.78 11.84
95619108 1 Rear bumper/tailgate moulding Estate 83.75 24.05
95619724 2 Tailgate moulding insert Estate 25.85ea 19.54
96059179 1 Badge, TZD TURBO Plaque style (earlier) 6.22 2.92
95582304 5 Bonnet chevron, chrome 4.58ea 15.75
95609863 0 Bonnet chevron, black 3.40ea SOLD
95568167 3 Bonnet catch protector .41ea 1.14
95589671 4 Bonnet buffer .99ea .60
95589346 3 Wing/bonnet rear edge seal block 1.97ea 2.79
95643658XX 1 Front bumper corner end set, black 6.77 3.22
95643658YB 1 Front bumper corner end set, grey 6.53 3.24
95624914 1 LHR arch moulding 16V, late Phase 1 & Phase 2 4496 149.69 73.74
95653193 1 LHR door moulding 16V Phase 2 89.13 22.94
95653195 1 LHR wing moulding 16V Phase 2 38.47 12.38
95612059XX 1 RHF wing moulding, 27mm 4754 7.92 3.51
95633444 1 RHF wing moulding, 27mm Stainless insert 4754 4.37 1.38
95633445 1 LHF wing moulding, 27mm Stainless insert 4754 4.91 1.27
95633443 2 LHR wing moulding, 27mm Stainless insert, saloon 4754 16.14ea 9.72
95612064XX 1 LHR wing moulding, 27mm Saloon 4754 9.73 3.44
95632337XX 1 RHR wing moulding, 27mm Estate 4754 17.07 9.92
95612072XX 3 RHR door moulding, 27mm 4754 16.40ea 24.36
95633439 1 LHF door moulding, 27mm Stainless insert 4754 23.39 8.80
95633438 1 RHF door moulding, 27mm Stainless insert 4754 22.16 10.32
95612058YB 1 LHF wing moulding, 27mm 4755 7.92 3.51
95612064YB 1 LHR wing moulding, 27mm Saloon 4755 9.17 3.97
95612065YB 1 RHR wing moulding, 27mm Saloon 4755 9.17 4.59
95632337YB 1 RHR wing moulding, 27mm Estate 4755 12.45 8.17
95612069YB 1 LHF door moulding, 27mm 4755 15.82 5.79
95612070YB 1 RHF door moulding, 27mm 4755 15.82 6.97
95612072YB 1 RHR door moulding, 27mm 4755 15.82 7.10
96044541YB 1 LHF door moulding, 52mm 4755 38.94 20.90
95656536 0 RHF wing moulding, 52mm Painted (Athena, Hurricane) 4755 27.74 SOLD
95653193 0 LHR door moulding, 52mm Painted (Athena, Hurricane) 4755 89.13 SOLD
95585105 1 RHR wing anti-chip tape Mk1? 5.58 4.19
CIT8021 2 Pinstripe St Tropez 10.91ea 13.26
CIT8055 1 Pinstripe Rendezvous 11.42 7.52
CIT7209 3 Badge Meteor 6.81ea 13.95
CIT8511 1 Badge, 19TXD Later version 3.01 1.60
CIT8090 1 Stripe kit Hurricane TZD Turbo 24.00 14.88
95612078 1 RHF plastic arch liner 37.81 13.07
95612060XX 2 Front bumper side seal 27.06ea 24.46
95561259 1 Rear door aperture seal 79.54 17.60
95584997 3 LHF wing moulding Mk1 9.09ea
95584996 1 RHF wing moulding Mk1 9.09 3.07
95568912 1 LHF door moulding Mk1 19.79
95568911 1 RHF door moulding Mk1 19.79 6.69
95568913 2 RHR door moulding Mk1 19.79ea 13.38
Glazing
95619450 4 Windscreen seal Saloon 50.79ea 68.92
95619451 1 Windscreen Clear 136.97 63.73
95653182 1 Windscreen Green tint 4496 142.89 89.66
95560673 1 RHF door glass Clear 53.50 19.86
95560674 1 LHF door glass Clear 29.72 15.30
95560676 1 LHF door glass Bronze tint 4495 27.00 25.61
96050176 1 LHF door glass Green tint 4496 52.19 21.55
95633344 1 LHR door glass Bronze tint 4495 32.49 30.92
96050178 1 RHR door glass Green tint 4496 55.52 26.29
96050179 1 LHR door glass Green tint 4496 62.95 26.29
96050180 1 RHR door ¼ glass Green tint 4496 17.94 7.71
95496514 1 Tailgate glass Clear, heated, saloon 91.10 37.60
95606651 1 Tailgate glass Clear, heated, estate 102.62 0.00
96051539 1 Tailgate glass Green tint, heated, saloon 4496 130.65 51.34
95592669 1 Tailgate glass seal Saloon 20.92 7.55
Miscellaneous
95552823 1 Spark plug wrench 3.73 3.97
96078629 1 Wheelbrace 4588 8.31 5.78
95495316 1 Heater matrix 75.40 40.01
95595456 2 Air extractor vent filter Saloon 2.15ea 3.22
95597261 1 Air extractor vent filter Estate 1.42 .78
95632283 1 LH mirror, manual 56.44 33.16
96077969 0 RH mirror, electric & heated 101.98 SOLD
95619708 1 LH mirror glass, electric 14.41 8.62
95633648 1 Mirror control knob, manual 1.41 .73
95624967 2 RH mirror control knob, manual 5.10ea 8.08
95638372 3 Mirror handle foam seal .76ea .78
95495888 1 RH mirror, manual (with handle) Mk1 90.05 44.26
95495892 1 LH mirror, manual (with handle) Mk1 64.95 47.09
95616731 2 RH mirror glass Mk1, “HOHE” 11.39ea 13.68
95614610 1 LH mirror glass Mk1, “BRITAX” 16.14 8.35
96047324 1 Heater hose to rear housing 1.7TD 5637 25.67 10.39
96090355XX 1 Coin box 14.67 5.87
95570247 1 Boot trim, rear panel Saloon 21.80 3.11
95576719 1 Rear lamp earth harness Saloon 15.54 4.12
95569072 1 Rear lamp harness, between lamps Saloon 21.89 16.42
95637364 2 Front brake pad wear loom 28.05ea 19.88
PETE SHAW
N T SHAW OF LOUTH
NORTH HOLME ROAD
LOUTH
LINCS
LN11 OHQ
TEL: 01507 603382
FAX: 01507 609198
UPDATED LIST OF BX PARTS FROM NT SHAW
- Tim Leech
- x 148
