any one know much about running a tzd diesel on Biodiesel??
the diesel isnt in australia so ther eis nto one here to ask about it
but thougth peopel here migth have an idea if it works
or if modifications need to be made to get it to work
if you guys hadnt already worked it out im a dirty hippie that loves his cits but likes to think i could be more enviromently friendly with them
lmao
Biodiesel in the turbo diesel engine
Magpi
- Our Trim Guru
If it is feasible, would be Bosch-pump-only, due to the well-documented problems with veggy-oil and Lucas pumps. If you must do it, a 1.9D with a Bosch pump would make much more sense to my mind, though I appreciate such a thing may not be a common creature in NZ.
jonathan_dyane
If you use the search function you will find lots of info. Bottom line is that the engine and injection system was designed for diesel, and will be more long-lived living on the correct fuel. Also, regardless of whether the injector pump is Lucas/CAV/Rotodiesel or Bosch, bio will eat the seals.
Lesson in Geography DLMDLM wrote:I appreciate such a thing may not be a common creature in NZ.
Anyways this could be another epic thread and for the record I know of someone who was running a Pug 405 Diesel on Chip fat oil. I followed him once up a hill no need to describe the smell
Last time I heard he had abandoned the idea because of the cost of filters and fuel pump overhauls, now that Diesel is down to a lower price and veg oil has increased in price.
Also have heard that the Pacific Islands are using cocunut oil for the Militery Police vehicles.
1990 BX19 TZS Auto 06/11/1989
- Our Trim Guru
Many thanks for your most kind but superfluous suggestions as to my knowledge of geography Kiwi
- but most of all apologies for Magpi for misattribution - I'm guilty of a serious a serious crime
I've not been on here a lot lately while concerned with some other matters so made an incorrect assumption about Magpi - who I at least placed in the right major Oceanic region - we don't normally get a broad swathe of Aussies beating a path to bxclub most of the time.
In any case, I think a non-aspirated BX diesel is probably as rare a beast in Aussieland as New Zealand.
I certainly wouldn't want to be "palmed off" with coconut oil and would "shy" away from it - even if there aren't any flakes to clog up the filters...
On the contrey alternative fuels to petrol and diesel have been popular in the lands down under for many a decade. CNG had a phase with LPG being more popular for the petrol versions and Bio fuels for the diesels were becoming quit prominant during the price hikes as they were in most parts of the world.
Probably because things have settled down price wise, well the kiwis for one are not whining about a 75% hike in pump prices in a year and the end of the world with a $2 litre
Also I think that because Diesel is not taxed at the pump and is based on the Kilometres driven they kind of figured the value of alternate diesel was not economical?
One thing I have noticed more eveident in NZ is that diesel cars are not prefered! Over all cost to run a Diesel model compared to a petrol often works out more expensive unless you extremely high kms.
Ironic then that Diesel is not a selling point!
- Our Trim Guru
Magpi
a brief history or coconut oil as Fuel in Bougainville
an adbirde version is that they had ntohing but coconuts to make oil with they used to run all there landcurser reoopies on a nut oil mix
worked very well
the bigest issues is getting glow plugs that glow at a higher temp as well as regular changes tot he filters
runnign of just straight veg oil does cause more toruble than making your own bio
takes longer to make bio then simply filing the tank with veg oil but its worth it int he end
worked very well
- Our Trim Guru
Have only just spotted your question.DLM I did not understand that last remark? Can you expand further?
I simply mean that the Aussiefrogs BX-owning contingent - one of whom I've met on 3 separate occasions - have always said that diesel BXs - and other European diesel imports - were rare as the proverbial rocking-horse droppings in Australia.
I have no idea about the New Zealand market - and wouldn't presume to know anything much about it, but in other Pacific markets where the BX was imported and a "following" grew up, e.g. Japan or Malaysia, the BXs imported and run seem to have overwhelmingly been petrol models too.
If that's just been a case of preference for petrol rather than non-availability of diesel variants, I don't know - but I'm just working on the basis of the BX owners I've encountered on various forums since the start of the millennium.
No doubt diesels from Japanese and other manufacturers have been available in the Pacific for a long time, and diesels have been ubiquitous in commercial, haulage and agricultural markets for many a year all over the world.
However, the French were way ahead of the game in the diesel engine for medium-to large-sized-cars in the era of the BX, and arguably still are in the forefront, given that volume worldwide concerns like Ford didn't fit particularly refined diesels until they got into supply agreements with PSA for the diesel engines in their mainstream cars.
I appreciate I've answered with my usual long-windedness - but I always like to take the opportunity to explain myself fully and clearly if I can. Does that do it?
Magpi
