Wanted another bx 16 valve phase 2
- rob-bx16v
Wanted bx 16v phase 2 preferably in white, will consider other colours but no red ones please. It has to be solid and sound underneath. My red one is now dead
rip c16 vbx
rip c16 vbx
bx16v p2 k reg red
bx16v p2 j reg green
bx gti 8v h reg blue
escort rs turbo g reg red
bx16v p2 k reg red
- Philip Chidlow
- x 25
- rob-bx16v
Rust, rust and more rust
shes gone on both sills, doth rear door shuts, rear chassis leg, rear chassis around the fuel tank, front of sill into drivers wheel arch, hole in bulkhead through to wheel arch, front chassis leg, and inner wing passenger side. And i bet theres more i havent found. Will cost too much to fix it all as its rear sub frame and tank out to do welding plus the suspension pipes have to come down. Im after another one ( solid underneath i hope ) so i can transfer as many bits over from mine then the rest will be stripped, engine and gearbox sold and shell scrapped, and plate transfered to new 16v
bx16v p2 k reg red
bx16v p2 k reg red
- rob-bx16v
I want another genuine 16v realy. Has to be phase 2 ( the later the better ie 91 H, J or k non cat ) and defo not another red one. Im no longer a member of the ccc.
Tim,
if you know of any good ones comming up for sale in the ccc will you let us know?.
Cheers rob
Tim,
Cheers rob
bx16v p2 k reg red
bx16v p2 k reg red
- Philip Chidlow
- x 25
- rob-bx16v
ive just been looking at the doc's resto thread and mine appears to have a hole in exactly the same places as the docs had ( wondering if they are twins ).
Im going to try and get another 16v but ive got a feeling its going to be hard to get a decent one as most of them are pretty much in the same state now due to age. If i can find one ill be swapping a fair ammount of parts over from mine as most are new plus i have an immaculate dash and interior in mine. If i cant find a 16v ill have to move on maybe thinking of a xsara vts phase 2?.
I will most likely be breaking the car at a later date depending on wether a 16v replacement is found first or not. and will put a post up as and when i start dismatling it.
bx16v p2 k reg red
bx16v p2 k reg red
- Tim Leech
- x 150
I will do buddy, there was one for sale in red not long ago which I think was advertised on here.rob-bx16v wrote:I want another genuine 16v realy. Has to be phase 2 ( the later the better ie 91 H, J or k non cat ) and defo not another red one. Im no longer a member of the ccc.
Tim,
Cheers rob
- docchevron
All BX's go there mate, valver or not.rob-bx16v wrote:ive just been looking at the doc's resto thread and mine appears to have a hole in exactly the same places as the docs had ( wondering if they are twins ).
Infact, pretty much any BX you'll find will have rot in all the same places.
Nearly always hidden by the factory underseal, but I've yet to find a "rot free" BX, they just do not exist.
Your's is fixable, anythings fixable really...
- rob-bx16v
doc, you are so correct. All the rot was hidden by the factory underseal hence why i hadnt seen it .
Im not after another 16v now as i have put a rescue plan in place to repair my own over the next 12 months.
Dont realy want to break it up
bx16v p2 k reg red
bx16v p2 k reg red
- x 88
If you do end up breaking Rob, I'd pay good money for various body panels....wings, bonnet, bumpers etc.
Good luck with fixing it up though
1990(H) 16Valve (Rouge Furio)
Don't let her die! If you need bits lets us know, anything to keep a beautiful valver alive!
xXx
xXx
Bride of Stinkwheel
http://weaselsemark.carbonmade.com
Citroen BX St Tropez
Still not over H592 AGW "Hugo" TZD Turbo
- rob-bx16v
Good news,
its not being broken up. Its currently stored in the garage at the mo. Ive treated all the rust areas to slow it down while i get things sorted. Trying to find a welder at the mo but proving hard also ive got a guy from a bodyshop coming out to have a look at the rear door shuts and inner wing to quote me. Ive already started buying parts for the underside as the rear subframes got to come out so im rebuilding it with new suspension spheres,cylinders,powercoating rear beam,arms,other bits etc etc. It should be better than new when ive finished.
bx16v p2 k reg red
bx16v p2 k reg red
