Bits and pieces for the bx
- rob-bx16v
Hi All,
Due to me unexpectedly finding out my 16v has some hidden rust i need to find £600 for welding/labour. Ive been having a sort through and found some bits and pieces to sell to try and raise some cash towards the repairs to keep the 16v on the road.
If anyone is intrested in anything please pm me with an offer ( nothing stupid )
First up is a bx gti 8v HP pump removed from a h registered 55,000 mile gti. Its untested and was kept as a spare. All the time its been stored its been kept primed with lhm, Is a heavy item so may be expensive to post.
Also a jvc cd mp3 player/radio. Comes with surround and ready to plug into a bx with 6 speaked system ( removed from our old gti )
Headlamp protectors ( pair ) removed from our old gti, In good condition slight chip on one of them but nothing major also some scuffing on the ends where they have been rubbing on the indicator lenses also need a good clean.
Universal mudflaps with fixing brackets never used
Finaly an ignition barrel + 2 keys i dont know wether its an ax or bx one. Any use?
If intrested any of the above can be picked up from st austell cornwall to save postage charges if local
cheers rob
cheers rob
bx16v p2 k reg red
bx16v p2 j reg green
bx gti 8v h reg blue
escort rs turbo g reg red
bx16v p2 k reg red
what needs welding, as that sound an aufull lot of dosh for welding,
also that ignition lock/switch i would say is a BX as the AX only has short leads attached
- rob-bx16v
both sills at the front, both sill ends, inner wing, scuttle through to the whell arch, rear chassis rail, subframe mount and rear wheel arch all need welding. also need a new out rigger in the drivers side rear wheel arch.
bx16v p2 k reg red
bx16v p2 k reg red
Dave ,DLM wrote:If the ignition barrel + loom are from a BX, then they're for a non-ABS model as they don't seem to have the extra connector hanging off the loom, though that could almost certainly be added without difficulty.
IMHO I don't think that is a BX ignition switch as the Brown plug only has two White wires attached to the ends !
Normally a BX fitment has a Black or Brown plug with four Red wires connected on the end of them and also a White plug with four White wires connected on the end of those and if it is for a vehicle with ABS it has a single Green feed fly-wire off one of the White wires for the ABS !
I hope that helps.
- maxgreenwood
- DLM
- Our Trim Guru
I can understand your scepticism, Max!Dave ,
I'm working from my memory and experience of fitting the Valeo switch I bought last year from GSF. At first I couldn't believe it was the possibly the right part at all.
It had only two outermost wires to the white connector, rather than the four of the original. It did include the ABS lead. I don't remember the colour or connects match on the brown connector, but can check.
I proceeded cautiously, thinking it'd have to go back to GSF. I made a trial fit first to the central console connectors before I made any move to remove the old switch, which had an intermittent connection in the wiring (the reason I needed to replace it).
To my surprise, it worked correctly, and has been on the car since.
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
Valeo replacement barrel kits have a generic loom, infact the citroen replacement part looks identical to that, i have two one in the car and one stored, and bar a missing ABS feed the wiring looks identical.
I suspect Rob-bx16v could easily plug the wiring into his BX (disconnect old, connect new) and see if the car starts and the lights etc work. 2 minute job i imagine?
- rob-bx16v
no intrest so its all going on ebay ( hp pump already listed ).
cheers anyway
dont know if its the way ive writen it but i didnt want mega money for this lot. Its just a step on the ladder to the big ammount ive got to find given myself 12 months to sort the car out
cheers anyway
bx16v p2 k reg red
bx16v p2 k reg red
- jonathan_dyane
Nobody is keen on the situation where they have to make an offer and so risk offending someone. A price is always vital if you want to shift something, even if it's only a rough guide...rob-bx16v wrote:no intrest so its all going on ebay ( hp pump already listed ).
cheers anyway
- rob-bx16v
ok fair enough,
nobody would offend me and im quite flexible on prices.
At a rough guess
£5 for mudflaps?
£5 for ign barrel and keys ?
£15 to £20 ish for jvc cd player ?
£5 for headlamp protectors ?
all plus postage charges on top ( or collection )
hp pump on ebay at mo with £5 starting bid.
hope thats any better
At a rough guess
£5 for mudflaps?
bx16v p2 k reg red
bx16v p2 k reg red
- rob-bx16v
headlamp protectors now listed on ebay
bx16v p2 k reg red
bx16v p2 k reg red
