New from The Netherlands: GT/Digit Turbodiesel Automatic
Alcyone
Post by Alcyone » Tue Sep 08, 2009 2:27 pm
Hello all, my name is Alex.
I live in a small town called Leerdam in the centre of The Netherlands, conveniently in the center of a triangle made of three major highways. Thirty-two years young, currently busy with supporting my very intelligent girlfriend, she does all the work while I do the household.
I've been driving hydropneumatics since I got my drivers license, GS X3, GSA, DS, CX but most of the time a BX Digit or GT with digital dash. I do most if not all of the tinkering and never go to a garage.
I drive a '85 GT with Digit wiring, computer and dashboard, mated with a 1990 A8A intercooled turbodiesel and a ZF 4HP14 GZ14 automatic tranny.
I conceived of the idea and built it myself, with the help of a few friends.
And since i'm an aviation nutter, the car's interior is continuously being modified to give it the style of a cockpit, planning on installing extra VFD's, switches and instruments. the car itself is called "Flying Frankenstein".
I'll probably read a lot here, and currently quite curious if the BX Digit exists in the UK.
Keeper of the site Goat
Post by cavmad » Tue Sep 08, 2009 3:38 pm
Welcome along, get some pictures posted up of your Digit please!
Vauxhall apologist.
Alcyone
Post by Alcyone » Tue Sep 08, 2009 4:03 pm
I'd like to, but I don't have permission to edit my own posts, so if I make a mistake, i can't correct it.
x 13
Post by mat_fenwick » Tue Sep 08, 2009 4:38 pm
There is a preview button, so if you click that before you submit the post, you can make sure it all looks OK.
Alcyone
Post by Alcyone » Tue Sep 08, 2009 5:18 pm
That's a bit different than I'm used to, our fora always let us edit our posts afterwards. But ok, here are the pics.
The only BX GT/Digit Turbodiesel Automatic in the world:
I've reverted to green instead of blue, VFD's show better contrast with a grey overlay when the sun shines on it.
The whole car was very cheap, only 100 euro's. A few bruises, scratches and dents, but almost no rust at all! The turbodiesel was only 50 euro's, the tranny another 50 euro's. And it all works fine :)
diesel consumption is a bit high, one liter every 15 kilometers, but i'm not complaining. Next march this one turns 25 years, that's bye bye roadtax, 950 euro's a year :)
These pictures were taken last february, I'll take a few in the sun soon.
Dashboard mod:
The hydraulics level light really works. Very easy mod but never seen anyone else with it.
There's an enormous list of future modifications, I'll post that later.
1985 CITROEN BX 19GT C1TBX
2002 Rover 75 CDT Connossieur SE Nav Auto R40TSL
2003 Rover 25 1.6i XL L33CHT
x 70
Post by Tim Leech » Tue Sep 08, 2009 5:24 pm
Wow that looks a bit like knight rider! 8)
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7HL
2002 Rover 75 CDTi Connossieur SE AUTO Nav
2003 Rover 25 1.6i XL 5 DR
Alcyone
Post by Alcyone » Tue Sep 08, 2009 10:10 pm
Maybe this topic fits better in the BX Gallery.
So if a moderator reads this: please give it a good kick in the right direction :)
Post by ken newbold » Wed Sep 09, 2009 12:15 am
:o turbo diesel auto Mk1 Digit :o
Can't think of anything that could be a rarer combination that this!
On a seperate note 950 euro's/year road tax :o :o
Alcyone
Post by Alcyone » Wed Sep 09, 2009 12:19 am
Having developed a slight case of temporary insomnia due to the local heat (it's 25C in the bedroom, argh) AND without a proper amount of alcohol to stop those neurons firing, I've returned to the pc.
If someone's interested, I have a YouTube channel with a few vids. One of the vids involves starting the A8A for the first time after fitting. http://www.youtube.com/watch?v=jvsNUy7r ... annel_page
x 70
Post by Tim Leech » Wed Sep 09, 2009 8:55 am
Thats proper cool! did you manage to get the revcounter working from the diesel engine?
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Alcyone
Post by Alcyone » Wed Sep 09, 2009 9:56 am
I'm busy with it: it involves four magnets bolted onto the camshaft pulley, with the Hall-sensor coil from within the distributor placed in the vicinity, connected to the transistormodule and HT coil, with a single sparkplug to release the energy. I believe that's easier than building some conversion logic, and the single plug is nice, especially if I can place it in a glass container filled with mercury vapour and argon 8)
x 70
Post by Tim Leech » Wed Sep 09, 2009 10:27 am
Alcyone wrote:I'm busy with it: it involves four magnets bolted onto the camshaft pulley, with the Hall-sensor coil from within the distributor placed in the vicinity, connected to the transistormodule and HT coil, with a single sparkplug to release the energy. I believe that's easier than building some conversion logic, and the single plug is nice, especially if I can place it in a glass container filled with mercury vapour and argon 8)
I have NO idea what your on about :lol:
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
x 13
Post by mat_fenwick » Wed Sep 09, 2009 10:35 am
How about a pressure transducer in one of the fuel pipes, triggering an op-amp to switch a transistor. My understanding is that most petrol rev counters are triggered by a switched 0V signal, so all you need to do is generate a 0V pulse once per revolution.
I notice that you have an oscilloscope so I suspect you will get what I am trying to suggest...
Alcyone
Post by Alcyone » Wed Sep 09, 2009 11:01 am
If my solution doesn't work, I'll try it :)
But once every crankshaft revolution, that's how the diesel rev counter works. I could take the signal of the flywheel-pulsegenerator, easier than meddling with the fuel pipes. I know the Digit rev counter wants a signal every 180 degrees of the crankshaft, every 90 degrees on the camshaft; that's why I thought my idea with the magnets is quite elegant.
Post by docchevron » Thu Sep 10, 2009 2:07 am
Alcyone wrote: But once every crankshaft revolution, that's how the diesel rev counter works.
Not quite. It's twice, since there's two slots in the flywheel 180 deg apart.
Awesome work though, if you ever bring that car to the UK then I simply MUST get a piccy of it next to dad's TD auto!
