I have some bits kicking around which are free to collector:
Carb, not sure of spec etc as never used it. not even sure where I got it, but it's free.
Box containing 8v XU rocker cover, HT lead seperator, distributor and thermostat housing from a 16RS
Diesel fuel filters....unsure on the type but can find out. One genuine in there.
16v radiator. Used, but in G.W.O
All free to collector. The only postage I can offer is through my work, and they charge £10 a pop mainland for any weight up to 30kg, even if it's just 500g! I just don't have time to sort it out of hours....life's got very busy!
Free BX parts
- x 94
Free BX parts
- Our Trim Guru
Kitch - I may well be interested in a diesel filter - but only if it's the late filter- -over-thermostat type -i.e. the setup where there's a priming bulb for the fuel system rather than a button/diaphragm arrangement on the filter housing.
I suspect that they may well be for those earlier Bosch/Purflux types given the age of the diesel estate you probably got them for in the first place - but let me know if they're not. Collection not a problem, obviously.
Is that carb the one with manual choke attached that I gave you a while back? If so, I think it it was originally removed from a late 16TRS in a scrapyard - but more than 5 years ago now so I'd imagine it will be well overdue for an overhaul/service.
- x 94
I'm not sure which filter it is mate, I'll get some pics!DLM wrote:Kitch - I may well be interested in a diesel filter - but only if it's the late filter- -over-thermostat type -i.e. the setup where there's a priming bulb for the fuel system rather than a button/diaphragm arrangement on the filter housing.
demag
- x 94
demag
Hi Kitch sorry I haven't got back to you the bloody house alarm and central heating have packed up so been a tad busy
If your sure you don't want any of them.
Also on your works list there are some handbrake cables, if there are any left I think I'm going to need two for the mot.
Dave.
1990 Bx TGS automatic.
- x 94
demag
