Hello,how do i dismantle the steering wheel after i open the 21 buksa,its just doesnt come of
thanks
steering wheel dismantle
Rgod
- Our Trim Guru
Discoil
Rgod
firt thing to check is the seal between the sphere (bomb) and the regulater,
i find sometimes if someone has fitted a new sphere and did not smear the seal with LHM before screrwing the sphere back into place it damages the seal,
another point they leak around that area is the thin plastic trickal return pipe which plugs into a short ruber pipe on the underside of the regulater,
this pipe can pop out if the regulater/acumalater sphere is flat/low or out of gas
