It happend to me today to times,their was a bad smell and some smoke that come out from the left brake,why does this happen?
The brakes were changed a mounth ago.
The left brake staies caught some times
Rgod
Most garages/people just fit new brake pads when the old ones are worn down. But they should service the brakes and make sure the caliper slides freely and the piston in the caliper is not seized up (stuck)
Or it could be the handbrake is adjusted too tight or sticking.
Normal maintenance will cure most of these problems with almost no cost.
- Our Trim Guru
also check the hand brake cables were they run through the giuds on the leg/strut, as the outter cable cracks letting dirt and grit in which causes it to hold the brake/s on sometimes
