They're clearing out all the old stock at work. There are some handbrake cables I think, but I know there are some cambelt kits (with rollers etc) for an XUD, carb fed XU and the later injected XU's like TXi's.
The early XU one might be catered for already, but as a guide I got the belt kits down to £25 (they're Gates too!) and the clutches down to about £35. Very limited stock! There are some more bits kicking around, I'll get the full list tomorrow. None of it is any good to me, and we've cleared some of it on ebay already.
Some parts reduced to clear at work - clutch, cambelts etc
- x 94
- x 94
Managed to find time to knock a list together of all the parts left:
256-520 Downpipe Gasket 1.4 (XY suitcase engine), 1.8D, 1.9D £1.60
256-528 Downpipe Gasket 1.4 TU engine £0.50
256-781 Downpipe Gasket 1.6, 1.6i, 1.9, 1.9i (inc GTI) £1.40
561364b Brake Disc (pair) 16v vented discs £18.00
561237b Brake Disc (pair) Non - vented discs £10.00
C1468 Air Filter 1.4 TU plastic top air filter £3.50
FC56 Rad Cap Metal cap £2.00
FCB2131 CV Boot 20x110x82mm £2.10
FCB2201 CV Boot 23x101x88mm £2.30
K015049xs Timing Belt Kit All diesels £45.00
K015050xs Timing Belt Kit 1.6 & 1.9 (carb only) £25.00
K025215xs Timing Belt Kit 1.6 & 1.9 (injection only) £19.00
P716 Fuel Filter N/A diesels (short type with rubber seal around top) £2.40
P725x Fuel Filter Tall Bosch type £1.50
P945x Fuel Filter Lucas metal element type £1.60
QCP2492 Water Pump 1.4 TU £11.00
QKT723AF Clutch Kit 1.4 TU £32.00
VCK3012 Clutch Kit N/A XUD BE1 only £28.00
VF024 Water Pump XU-type, 1.6/1.9 upto 5409, XUD 84 - 86?? £11.00
VF025 Water Pump XUD - type 1.8TD & 1.9D 86 - 93 £10.00
VJB141 H/Brake Cable all £3.50
VJC665 Clutch Cable 1.6/1.9 exc 16v, 1.8D & 1.9D £7.00
VK059 Wheel Bearing Kit £24.00
VR604 Brake Hose not handed - 435mm length £5.00
WA6185 Air Filter 1.6/1.8D/1.9D/1.9 GTI/16v (oblong type) £1.70
xd183 Dizzy Cap 1.4 TU, 1.6/1.9 XU (Bosch type) £5.70
If anyone wants any of it let me know ASAP so I can stop them ebaying any of it.
BX nut
bx bits
Hi
I'm very interested in the Timing belt kit for the 1.9D engine. Does this fit all diesels? Also the diesel filter short type, air filter oblong How would you like payment and how much for postage? unless you are going to the ace cafe on the 3rd? also the mud flaps as well
many thanks
Allan
many thanks
Allan
- x 94
BX nut
what mud flaps?
Ooops
It had been a long day. Sorry forget the mud flaps. ha ha
ritmo
Aerodynamica
Ello old son, you can get belts 'n stuff from Hellfrauds (oops! sorry, Halfords) for things like that - one of the few things they're actually useful for still...ritmo wrote:Any tzd turbo timing belts left?
Also I think I need a new belt for the hydraulic pump, any of those?
Thanks
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
ritmo
- x 94
Just an update - still got some stuff left. We're popping it all on ebay as buy it now or best offer type affairs. A little hint is that the buy it now price is the COST price to the company I work for!
Heres a clutch kit for a diesel n/a with BE1 gearbox:
http://cgi.ebay.co.uk/CITROEN-BX19RD-DT ... 2c5193444d
And a timing belt kit for a 1600 or 1900 petrol (non-injection)
http://cgi.ebay.co.uk/GATES-TIMING-BELT ... 2c518b584a
Timing belt kit for a 1400 TU:
http://cgi.ebay.co.uk/NEW-TIMING-BELT-K ... 2c518b5529
And this should be the listing for all items currently on offer. There will be more, and some of the BX gear has already been sold (including a bit bought by Justin on here!)
http://shop.ebay.co.uk/hendy_eshop/m.ht ... ksid=p3686
Before anyone asks theres nothing in it for me, I'm not on commission! But if it doesn't sell they'll bin it and the bin is probably a long way from you guys!
