LHM leak
Martyn
LHM leak
Post by Martyn »
Big problem - stranded without lhm. Can I use engine oil in emergency. Crashed into lamppost in reverse yesterday so car knackered. \\\\\\\\\\\\any ideas?
1992 txd
1991 1.7 tzd
jonathan_dyane
Post by jonathan_dyane »
Engine oil will work in an emergency, the thinner grade the better. Citroen used to advocate use of 30 grade engine oil in an emergency.
I seem to remember somewhere that you could use mineral oil as an emergency, but then you're going to have to purge the whole lot out of the system. Wouldnt it be far easier to just buy some lhm whilst leaving the car stranded, or is it somewhere where it cant be left? Cant you get breakdown recovery to collect your car back home? How bad is the leak?, no point in filling up the lhm tank with either oil or lhm if it pisses out that fast that you wont be getting far anyway. Bit of a bummer hitting a lampost, not much give in them, better than a tree though.
as MULLEY says
only mineral oil not semi or fully synthetic,
