A bit of an introduction is in order - My name is Josh, I live in London and I'm 18 years old. I currently drive a 205 XS, but I am in the process of replacing it with something a little more comfortable... which lead me here.
I've been weighing up my options for a replacement for the 205, and by complete and utter chance decided to try my luck at getting a quote for a BX GTi 16v (after I was drooling over the thought of a MI16 powered 205!)... turns out not only can I get insured on one, but it's ridiculously cheap, probably due to not many 17/18 year olds wanting one!
To be honest, I reckon a BX could be utterly ideal for me. I'm after something that is going to retain the fun of the 205 with a bit more room and comfort.
What I do have a few worried is about is namely the suspension. A bit of limited research says that the spheres should be pretty easy and cheap to replace (and need to be done regularly). Is this still the case?
Is the suspension a bit... wallowly? I know I said I'm after a bit of comfort, but I would enjoy to do the odd track day/cruise along some B-Roads. As an apprentice mechanic for a bentley garage I have gotten to sample the legendary Hydropneumatic suspension from the passenger many times. While the ride comfort is second to none, I'm not sure how they would deal with Brands Hatch!
I don't suppose there is any way to improve the GTi suspension much further either?
And what's this deal I've read about them all having height adjustable suspension?
Other general questions are:
Rust - From the bit of reading I've done here, it doesn't seem to be an issue?
Day to Day running - Are they
Reliability - I know most of it will come down to the engine (which I understand can become a bit tired after 100,000 miles plus?), but in general are they reliable cars
Brakes - Are they really as good as I've heard?
Interior - What should I expect in terms of interior quality? Are BXs well screwed together? (my 205 isn't
Weight - Do they really weigh between 900kg and - 1100kg? Not massively important, but for what is quite a large car I expected them to weigh a bit more
How much should I expect to pay for a 16V GTi? A scan of your adverts shows one for £700!
Any other BX models I should consider if you recommend me not to go for a 16v GTi?
Thanks for the time
Josh
