BX 1.9 1995 leaking pipe
n11xxy
Post by n11xxy »
I have a leak on the suspension pipe, its where it tee's off to the middle front sphere (accumilator sphere i think) and then goes back to the reservoir (or its coming from it, not sure if its flow or return)
does the whole pipe need to be replaced? or can you buy a tee piece for this?and what would be the best way to do this? The tee piece is black rubber.
thank you for any help
Mark
Jayboy
Post by Jayboy »
Sounds like that will be the small octopus - or "squid" as the parts man in my Citroen dealer calls it! Could possibly be bodged but hard to say without seeing it. Best option is to replace - think they're about 30-40 quid?
Nowhere near as hard to do as the main octopus is!
