Tasty Athena - Part Deux
I'm in a quandary ... (that's like a 2CV, only smaller) and I'd like some advice from the learned membership.
I'm the bloke who bought that 'tasty' Athena The offending BX and the purchase has given me something of a headache. The thing's the complete opposite of my current TZD Estate I bought the Athena to stand-in for while I restored it.
I bought this Athena because my TZD needs a facelift. I bought the TZD 4 years ago from an elderly gentleman who finally gave up driving (after first having gently squished the corner of every bumper on the car) and, to my shame, I've used it as a runaround ever since while restoring our 19th century cottage - and it shows. The interior needs taking out and vax-ing, the black surrounds need repainting, there's an annoying little ding near the fuel flap, the passenger window switch in the driver's door has stopped working .............. but the car's only done 80k. It runs perfectly .. but I really like this Athena. The problem is, the bloody thing's immaculate.
However, I've reached the conclusion the Athena's been neatly clocked. I finally twigged (after findig shagged radius bearings, worn driveshafts, almost clapped clutch) when the odometer rolled over to 63,000 miles last week - and all the digits went all squiffy, a classic symptom. So, I suspect it hasn't done 62k at all - more like 162k ..... but that's not the real problem, I can easily fit new rings, shells, driveshafts and a clutch - I've already ordered new trailing arm bushes and it's worth it for this car's general condition. It really is mint (ish).
The problem is the TZD. If I try and restore both, I'm going to get severe grief from herself ............ and I don't know which way to jump - cosmetic or mechanical. If I fix the Athena, I'm going to wind up with a beautiful hatchback with a sunroof, an almost silent and smooth petrol engine and an almost as-new interior. If I respray/restore the TZD overwinter, then I'll have to break the Athena at the end of it because nobody'll buy it with the problems it's soon going to have after another 6,000 miles.
Both cars are MOT'd until the end of next year, both are taxed - and I'm tempted to sell off the TZD on Ebay to fund the rebuild of this stunning - but worn - Athena.
Is this a bad move or not?
Re: Tasty Athena - Part Deux
Aaarh!!!
- MULLEY
Keep both, get the Athena upto showroom standard & just use it for summer use & for going to car club meets to show off its immaculate condition. Just use the tzd as your everyday car, simples
If only real life was that simple.............
Our 2-bay garage houses the new Bora - leaving just the one bay for me and my tools and motorbikes. Whichever car gets restored goes here, while the other one lives outside - or that's the plan.
However, it looks like both of 'em need to come into my lair ........... and if I try and evict the Bora, my life's going to be worth about as much as a pre-owned bogroll - and I'll be about as popular hereabouts an' all!
The really ideal solution of course, would be to nick all the bits I need off the TZD - including the engine - and transplant them into the Athena, but that's not realistically going to happen because it'll be a mechanical nightmare - the ABS swapover for a start is one issue I don't want to play with.
I dunno - I thought I'd bought a tidy BX for temporary use. I didn't expect the blasted thing to grow on me!
I'm with Mulley - keep them both. You probably wouldn't get much for the TZD anyway!
Bora? It's all in the name isn't it? And it's probably more resistant to the weather anyway so shove it outside.
As for the wife, wait til you've got five BXs, two of which are more ornaments than useful objects, then two seems really modest.
Well, you knew you wouldn't get a useful answer around here!
I take my life in my hands every time I mention the word "BX"! You've no idea what it's like living with a technophobe .......... <sob!>
There's also the slight question of space .......
- Tim Leech
- x 150
Regarding the squiffy numbers, alot of BXs are guilty of that and it seems to be a design fault, you normally find they even out after a while, another way is to tap the top of the binnacle hard as it turns over its next 1000 miles and they all line up again!.
The body looks too nice to have done so many miles, I would spend the money and get the bits done, regarding the clutch it may just need the cable adjusting?
Yeah ..... I tried that. So I popped off the dash binnacle - and the speedo head's been out.
Trust me, it's been wound back - honest guv', I can see the instrument screwdriver marks. I used to examine motor vehicles for the RAC in a previous life when I owned a small garage, so I'm kicking myself for not spotting this. The leading zero in the odometer was very slightly misaligned when I first saw the car after winning the E-bay bid on it, and it did feel a bit 'floppy', but I was seduced by the appearance, the as-new steering wheel (which was fitted crooked - anyone see that as-new one on Ebay - I wonder if they're the same..... ), immaculate carpets and the blingy bits.
I had the clutch actuating mechanism off yesterday in case the arm had developed a split - but it was fine. The reason it judders and needs a lot of (very squidgy) pedal travel for disengagement is simply wear - I suspect the friction plate is also flat as a pancake with age and has lost its 'springs' .... both axial and radial. Take-up is pretty fierce.
To say I feel a prat would be a slight understatement, however, I've certainly got £550 quids worth of tidy BX, so I can't really complain too much.
Is there a compatibility list anywhere around that shows what Peugeot bits fit a BX? I'm thinking of trawling for a complete engine and gearbox, service it on the bench (cambelt, pump, idler, et-al, and then swap it out one wet weekend and keep the old one as an emergency spare.
Gets complicated this BX lark, dunnit?
- MULLEY
I'd leave the bora outside, its newer & can take the weather, if wifey doesnt like it, tell it to her straight, you're leaving otherwise
- MULLEY
I look forward to popping over, whats for tea
looks like the estate has been front ended at some time in its life, usual tell tale sign upside down chevrons on the bonnet
