One of the problems with the bearings is that they don't fully rotate, and only operate over a small arc, so have to put up with the loading being repeatedly taken by a small part of the track and likely only a very few of the rollers. (The small needle rollers used on the Mini, would be an even worse case, and the toll taken by water ingress/rust on these would be quite serious.)
I think you're right: given 'open' bearings, and if some added lubricant could be 'mobile' (eg oil+grease, or very heavy oil), some regular Citrobics would help move the rollers around a bit more than usual, and hopefully move some of the lubricant around.
Replacing Rear Arm Bearings
- LHD, NA, AC, RP_5800
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 50
Re: Replacing Rear Arm Bearings
The bearings don't need lubrication. They only ever rotate through what, 30 degrees? The point of greasing is to keep moisture out.
Every fully shagged arm I've ever taken apart has had the rollers rusted to hell. This rust, coupled with standing, is what eventually causes a roller to bind, twist and start eating the housing. So the lube/grease is to keep the moisture out rather than some how minimise friction like a normal rotating bearing.
I've strong views on the idea of needing continual lubrication, most are previously documented in the forum. There are some frankly Ill thought 'solutions'. I don't see the point. Fitting them correctly in the first place, and regularly using the car, keeps the bearings in final fettle for a long long time. I think my current ones have been in around 20 years, not showing any issues yet.
Agree about the rusting. When ours failed on our previous '89 19D (failure occurred around 1995), the OE bearings were found to be rusty and dry. This was despite the car being used more or less daily for its entire life.
I think you're right about the principal need is to keep water and off the bearings.
Sealed ones would be nice, but not sure whether anyone has managed to identify any.
Does anyone have a new set available, which they could provide exact dimensions for?
I've many sets, and planned to measure and upgrade next time I'm doing rear arm bearings. Just hasn't happened yet
If I find an SKF kit while I'm tidying the garage, I'll dig the part numbers out
