Also, my 16v has the tin sump and I'd like to get an alloy one for it... please PM if you have one for sale. Cheers
I need a knob! and a sump
djoptix
A while ago I bought a red pool ball gear knob for the 16v and sold my standard gearknobs. Now I've gone off the pool ball one and I don't seem to have kept any spares! Does anyone have a standard gearknob they could sell me? Beer tokens await.
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
djoptix
Kevin B
Not quite so, the aluminium spacer you refer to, has two cross braces cast into it, with the intention that these increase the rigidity of the alloy crankcase, hence you will only find this item on 16v engines (and are always fitted regardless of what type of sump is fitted). Furthermore whilst alloy sumps from other XU engines will fit, the genuine 16v version has cast in fins on the the exterior surface to aid heat rejection.Any XU engine ally sump will fit, ie an alloy sump from a 1.7td or 1.9td will fit. I have a 1.9TD sump on my valver. If i remember correctly the tin sump has a spacer which you dont need for the ally sump. There is also no gasket for the ally sump, just use instant gasket in a tube..
It is my own experience/opinion that the alloy sump option was only ever ever fitted to mk2 16v engines, unless the car was fitted with aircon.
There is one (at least!) non Mk2 16 valve BX fitted with the finned sump - my 1.9TD! The spacer braces foul the oil pump, and the sump fouls the flywheel. Also, the holes for the A/C compressor are a different size to the smooth ally sump. None of the above improved my mood when trying to swap the sumps in the rain...
djoptix
The smooth ally sump from a diesel with A/C that I used originally, had tapped lugs for a pressed steel mini baffle (not sure what the purpose was) but possible a more substantial baffle could be screwed to these lugs.djoptix wrote:A sump that I can put a baffle in
Hmm, the ally sump may give a small increase in crankcase rigidity, but if you hit a rock is more likely to shatter, whereas the tin/steel one would probably just dent (don't ask how I know!)djoptix wrote:A sump that's stronger than the tin one
When changing to the finned ally one I seemed to find that the oil ran about 10°C cooler in the same conditions. I don't know whether this is down to the fins or the possible extra capacity from having the spacer (I haven't measured the difference in the amount required to fill after an oil change).djoptix wrote:A sump that cools well
Has to be ally...djoptix wrote:A sump with aircon compressor mounts
Is that any clearer?
The ally spacer was also fitted to some 8V GTi engines, possibly later models.Kevin B wrote: Not quite so, the aluminium spacer you refer to, has two cross braces cast into it, with the intention that these increase the rigidity of the alloy crankcase, hence you will only find this item on 16v engines (and are always fitted regardless of what type of sump is fitted). Furthermore whilst alloy sumps from other XU engines will fit, the genuine 16v version has cast in fins on the the exterior surface to aid heat rejection.
Pretty sure 16v ally sump engines dont have the spacer, infact i think it states this in the parts catalogue. I can't see that a fairly flimsy bit of alloy is going to make a significant increase to the bottom end of the sump!
As said, i've a XUD alloy sump on mine and it IS finned.
Kevin B
Like what the doc said.docchevron wrote:All D6C engines had the spacer, even if it has a steel sump.
If you want all of the above I suggest you look out for an Alloy sump from an XUD11 engine as this already has a steel baffle with a trap door fitted. It should fit straight on with little or no modification.Well, now I'm confused! Ideally I want... (in order of priority)
Which is best?!
