involves a 1.9 diesel zx engine a 4wd bx and some spanner action to get my old tzd up to spec for some trail rides through the outback.lol.
have imported my old 4x4 from the uk now for the big swap fest to get it on the road.lol.
heard that you cant get the diesel to work. but i am a trying lad and i dont sleep till it does.lol.
BX 19 GTZD 4X4
djm666
BX 19 GTZD 4X4
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
- x 94
Kevin B
Quite so, as the 4x4 Bx is fitted with the lowest overall gear ratio of any of the Bx range.Apparently getting some worthy gear ratios is the tricky part, as all the 4x4's were petrols and have petrol ratios.
Some years ago there was a dieselised version featured in the CCC magazine.
You could try different ratio gears (by using the gears from the ZX gearbox) in the gearbox and a higher ratio final drive (what would be the differential in a 2wd bx gearbox) but in the bx 4x4 the differential is moved to the transfer box.
This would however have the undesirable effect of transmitting increased torque through the notoriously weak splined coupling between the gearbox and transfer box.
djm666
bx diesel 4x4
i love the bx's it is my hobby and i spend all my money on it.lol. rather than drinking all the time and being on the streets i am in my garage fixing and playing. i will strip the be3 box from the diesel down and put al the gears into the 4x4 think they still have a bolt on bolt off crown wheel so should be good. no probs there. and the rest i have tons of spares of.lol.
yeah i saw the 4x4 estate td on ebay before i left the uk dunno where it went.?? or wether they got the running sorted?
i will have to try harder to get some pictures up, will have to ask my computer wizz brother.lol.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
