noise from the drivers seat when you plonk your arse into it.lol. now i am not to big but it still creaks.lol.
i pulled the seat out and found nothing to out of the ordinary, but a lot of movement in the hinge in the middle of the seat. looking at it i will have to strip it and weld a new peice of steel tube of the right size to cure it. a bit of grease has done wonders for now.lol.
any body else had these issues??
seat noise
djm666
seat noise
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
Linegeist
YES!!!
The driver's seat on my bloody Athena sounds like it has terminal arthritis - every time I so much as twitch, it sounds like I've farted through a full set of strangulated haemorrhoids! Driving down a bumpy lane gives off a cacophony like a bullfrog's bloody orgy.
The damned thing's going to feel the heat of my MIG welder - as soon as it gets warm enough for an old fart to get into his workshop without his nuts dropping off or his bladder letting go!
- x 94
Ah the squeky seat problem
Its called Wear and Tear depends how bad it is as to how much effort you want to replace it.
Actually now you mention I had not really noticed it until now but then it blends in with those annoying dashboard creaks and rattles. Frustrating even more when they are out of reach on the passenger side and you just can not pin it down.
djm666
seat issues
pulled all the plastic off the seat low and behold would you beleive the noise was still present.lol. Then pulled the foam and cloth off to cut out and weld a new rod into the frame. one that had less movement in it.lol. still made noise.lol. then started with the welder.lol. used a rear arm bolt to repair it now it really it good no noise .lol. bloody marvelous.lol.
yeah i am not to well set but it still annoyed me to get in and out of the car.lol. weird that it made that much noise. but it all good now.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
