Replacement hoses - dealer supplied, or hose 'off the roll'
andycadabra
Post by andycadabra »
My local Latino garage and at last managed to partially remove perhaps one of the worlds most inaccessible hoses (the return from the heater radiator to the flange at the back of the engine). Seems like they now need me to supply a replacement hose.
When I last tried to get a similar one at the Citroen dealer it was going to take a week to get one sent from France, so I found a local motor accessory store that sold hose 'off the roll'. They fitted this that the high-pressure in the cooling system probably caused by a faulty head gasket blew a hole in it fairly quickly, and they fitted a bit of hose they had lying around, which worked.
I'm pretty sure I won't be able to get this hose at a main dealer without waiting a week for it, and the garage need to free up the space, but I hesitate to get more hose 'off the roll', unless it's better quality.
The last one did seem to be British made, so should have been up to the job, but it does seem to be a lot stiffer than the original hose they removed. The garage told me to get 'oil resist' hose - is that an option?.
Any thoughts on the matter would be appreciated.
The hose on a roll has to be proper 'heater hose' and not ordinary water or air brake hose, if it is it will last on a straight run but it won't be any good if you have some tight bends as it will just kink and close up inside.
andycadabra
the one I got was printed with 'heater hose', but it burst before it left the garage. Admittedly there was extra pressure in the cooling system at the time plus some washing-up liquid, but it shouldn't have done that.
this particular hose is a nightmare to replace, and browsing on eBay I've noticed that you can get 1m of 19mm bore silicone hose that will stand up to 200°C for £15. I'm not sure I'd be able to get one locally, so the garage might be pissed off to have to wait 2 or 3 days for it, while it's taking up their space!.
I think your better off ordering the correct hose which should outlast the car, surely the garage will have other cars to work on whilst waiting for the right hose?
andycadabra
I've managed to order one through a main dealer. £15 and it'll be in in 2 working days. I've had to pay up front so I just hope it's the right one..
I think thats the right decision for reliability and piece of mind.
