Was just clicking about, as you do, and came across this:
http://www.club-306.com/guides/306_turbo_tuning
It'd be the same principle wouldn't it?
Sure i can see all the appropriate bits in there somewhere!
A mate was driving behind me yesterday, and apparently I'm already getting a "little too much" black smoke so it needs tweaking anyway.
Thanks in advance.
Same for 1769cc turbo?
corni6580
No BX!
- Want any manual diesel
Volvo 440 GLT Turbo '95
Corsa Twinport '05
Corsa Twinport '05
Pretty much yes, it all applies, or at least as much as I could be bothered to read!
It's been well mentioned on here before about tuning up TD's, but in essence the proceedure is the same be it 17 or 19 TD units.
Things like Bosch or Lucas pump make a difference (much easier to tune a Bosch pump)
Turbo makes a difference too, IE Garrett or KKK...
Tourist
the 1769 is a far better engine to tweek really. There's more meat around the cylinders, so they tend to blow HG's a tad less than the 19TD, Ok, it's only 3mm difference in the bore, but 3mm is still 3mm extra.
IMHO the 17 is a sweeter engine all round really.
