I'm after an unfettled 16v engine loom from either the motronic 4.1 (2 row pins, no knock sensor) or 3.1 (3 row pins, with knock sensor). the loom I'm currently using is suspect and I want to try another.
Thanks,
Guy
16v engine loom wanted
24seven
24seven
Kevin B
That would be £70 plus your old loom in exchange.To be honest I've no idea what they're worth, my only guage being that I've seen bespoke 205-Mi16 conversion looms sell for around £70 in the past
I am slightly puzzled why you want either 2 or 3 row as they are obvoiusly not compatible, unless you are going to undertake some seroius wiring loom revisions, and are familiar with the pin out diagrams for the Motronic 4.1 and 3.1 ECU's.
I think your going to stuggle to find one of the looms for £25, so good luck.
24seven
