Front end droping
Stewart (oily!)
Front end droping
Post by Stewart (oily!) »
Hi all, just been to the car wash, sat there with the car raised up to max height, switched off the engine and within five minutes the front end dropped down in a series of jerks? at the end the rear was still up, the front was down near normal height, should I worry? will this be a strut on the way out? or is this a height corrector issue?
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Keeper of the site Goat
Post by cavmad »
One of my old ones did that, I think it was the TGD hatchback. However it still got me round for ages. I put it down to struts which creaked a lot anyway and never let it bother me, I got used to it dropping at will!
Vauxhall apologist.
My guess is that if you replace the struts you will find that the ride improves considerably. Lubrication may help but isn't the whole answer.
Oscar
Post by Oscar »
Try lubing the height corrector linkages underneath the car.
Of course this should be done with the car on axlestands.
Stewart (oily!)
The struts are lubed internally using the tried and tested method AND the bits of towelling under the gaiter, I will get under and have a look at the front linkages though as that is a distinct possibility, amongst fitting some new seals, door cards, heater matrix, brakes, got to be good for france next summer :)
Stewart
Oscar
Post by Oscar »
My God Stewart, I wouldn't have mentioned axle stands if I'd realised it was you!
Because I know you're more sensible, not because I want to see you off!
Stewart (oily!)
Oscar I dont bother with the axle stands any more :twisted: I just nip under and if it starts to drop I sort of do a press up in reverse :D :D Righto, off to drill some spheres :D :D
Stewart
Oscar
Post by Oscar »
Before you go, just hold this cigarette lighter while I look for the petrol leak.
Post by cavmad »
Stewart, have you got some decent struts if you need them? If not drop me a p.m...
Vauxhall apologist.
Stewart (oily!)
Cheers Cav for the thought but there are some struts in the parts pile :D
Stewart
