Leaking Hydraulics
Will
Leaking Hydraulics
Help!
My recently purchaced H reg 90000 miles BX TZD which is gorgeous has a continuing problem with leaking fluid from the return pipe adjacent to the nearside front wheel. It keeps blowing out of a push fit tight rubber connector. The garage have tried to clamp it on with cable ties but after a few miles it comes out again. Third time now! in three days
The other small problem is the light behind the speedo does not work, which is not great at night. Is this something I can do or is it the garage.
Thanks
Will
Thanks
Will
Give a retired Greyhound a forever home
It could be your accumulator sphere is flat (the one in front of the engine) how often can you hear the ticking?
I'd advise against fitting any clamps or clips as this could cause the pipes to blow off elsewhere, somewhere very difficult to get at.
Try to find out which pipe exactly is blowing off.
The dashboard lights are a bit tricky unless you know where the securing screws are. I'm sure there must be a thread on here somewhere detailing this.
Incidentally, if you cannot see the speedo you will have at least 4 bulbs blown maybe more. Do the other dash lights work? if not it could be the dimmer at fault under the steering column.
I've moved this thread into Technical...
There have been several threads about changing the dash bulbs, so I've moved the best of those into Technical FAQ, here.
Not being an expert on the hydraulics, I'd guess that it would be down to wear in the main seals allowing more LHM past (hydraulic seals are designed to leak slightly for lubrication of the seal itself). If too much is leaking past it will probably start to pressurise the return pipe system, which is not designed to be pressurised!
It might be, on the other hand it may have just worked itself loose. If its been re-fitted, if it blows off again then i'd deffo suspect the strut. Does the strut that the strup pipe its connected to make any noise at all whilst driving (they should be silent)? How about when starting the car 1st thing in the morning, is there any strut groan whilst the car rises? If there is then its probably the strut. See how you get on with it is my advice, get a spare strut ready just in case & if it does blow off then just replace the strut. I had a groany strut last me a year before it blew the pipes off, fitted a 2nd hand one, no more probs since.Dollywobbler wrote:The strut pipe on my BX was discovered to have come off at the service. I was warned it could be a strut issue. Anyone got any advice on that?
Agreed!mat_fenwick wrote:Not being an expert on the hydraulics, I'd guess that it would be down to wear in the main seals allowing more LHM past (hydraulic seals are designed to leak slightly for lubrication of the seal itself). If too much is leaking past it will probably start to pressurise the return pipe system, which is not designed to be pressurised!
If the strut pipes blow off then there must be significant fluid flowing where next to no fluid should be passing.
I've had a strut fail in this way on the A3/M25 and it split the return pipe.
Even topping up with LHM I could only get 3 miles before the suspension was on the front bump stops and a few miles more before I lost power steering so had to park up and do a strut replacement at the roadside as brakes would have been lost shortly thereafter and the LHM trail was much more expensive per unit distance than the petrol!
- x 117
Confirmed. This will deffo be a badly worn strut causing the return pipe blowing off.
New internal seals - if still available - are very cheap but it is a pig of a job to get to them.
back to the original post
i think the steering ram blowing to much presure by its seals, can also cause the push fit pipe behind the N/S/F wheel on the safety valve to pop of,
Jaba, have you managed to renovate any struts yourself?
My thoughts exactly. That why we'd need to know which pipe is coming off before going any further.citronut wrote:back to the original post
