Diesel Injectors cfm, any idea?
ssray
Post by ssray »
Hi guys, any body know approx the flow rate is for the injectors on my 1.9d n/a bx estate? Thanks Ray
I can't help you with statistics but if this is related to how it works or the pump workings you may find some useful links on this page
http://users.skynet.be/sn/manuals.htm
ssray
Post by ssray »
Cheers Jeremy, i dont think i need it now , i`m experementing with a n/a water injection type system and thought i`d need to know the flow but i think i can get away without it, i`m just not sure to use as a `jet` or fogger for the water/alc` if i can get a needle i may try that as it would seal better than using a jet that i`d have to drill a hole in the inlet pipework, i`m using the bx as a rolling lab so i can transfer it to our big car 19/25mpg on a good day, any little will help.
Ray :roll:
p.s. bx is doing around 35-40 mpg will post after fitting, total expense so far £6.
