help need pipe96126771
mark two
Have traced other 3 front to rear pipes but unable to finds ABS feed pipe, as above. Any help would be greatly appreciated!
djm666
if its still avalible from citroen here is the trad price inc VAT for that part No.
96126771 HYDRAULIC TUBE 13.37 GBP 15.71 GBP 15.71 GBP
this is the main rear brake feed 4.5mm to the rear of the car, which goes from the union on the bulk head to the three way union on the rear axle
Stinkwheel
Cant any of them make up a pipe for you?
Take the old one off if possible and take it to a citroen independant and they should easily be able to copy it for you with a roll of pipe and the correct 4.5mm flaring tool.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
mark two
were abouts in Kent are you Mark,
im in St Leonards on sea
i have a box full and more citroen hydralic pipes, new old stock, not sure if i have that pipe as some the part No. lable has gone a wall,
dose your freind have the pipe flairing tool/s to make up citroen pipe/s/ ends,
if not and i dont have the pipe your looking for ask Martin at PLEIADES as he will make you one up if you send him the pipe length and diamiter,
heres his phone No.
01487 831239
heres his phone No.
01487 831239
