Chrisj
Posts: 3 Joined: Sun Feb 14, 2010 6:20 pm
Quote
0
login to like this post
Post
by Chrisj » Sun Feb 14, 2010 6:23 pm
Hi all,
I've recently purchased a 16v bx as a small restoration project.
It is missing a few things, one being the instrument cluster containing the speedo/tacho/oil/water gauges etc.
Has anyone a set?
Many thanks
Matt H
Posts: 1000 Joined: Mon Dec 17, 2007 12:02 am
Quote
0
Post
by Matt H » Mon Feb 15, 2010 7:14 pm
I've got a set from a 205 GTi you can have for a tenner if you can't find any from a BX.
They fit straight in without any modification.
Has got about 140,000 miles on the clock though...
Posts: 2241 Joined: Wed Jan 28, 2009 11:51 am
Quote
0
Post
by RxBX » Mon Feb 15, 2010 7:34 pm
Chris I've sent you a PM !
Hi Matt,
Just out of interest where does Tachometer SOLID red-line start on the 205 GTi
As on the BX GTi set that I have, the SOLID red-line markings for the Tachometer starts at 6,200 RPM and is marked up to 8,000 RPM.
IIRC the 16V models SOLID red-line starts at 7,200 RPM and also is calibrated to a maximum of 8,000 RPM, so at least that's the same !
Matt H
Quote
0
Post
by Matt H » Mon Feb 15, 2010 8:19 pm
Here's a pic:
Red line is the same as the BX 16v IIRC (Couldn't tell you for sure without looking outside at mine and it's too cold
) But not the same as the BX 8v GTi.
Chrisj
Quote
0
Post
by Chrisj » Mon Feb 15, 2010 9:24 pm
RxBx pm replied thank you.
I have few sets of 205 clocks around and about but i'm really after the bx ones.
Thanks
Quote
0
Post
by RxBX » Tue Feb 23, 2010 11:19 am
Hi Chris,
Chrisj wrote: RxBx pm replied thank you.
I have returned a PM back to you now !
Thank's
Oldred
Posts: 1 Joined: Sun Feb 21, 2010 10:47 pm
Quote
0
Post
by Oldred » Tue Feb 23, 2010 12:36 pm
Chris what other parts are you after for your BX restoration?
oldred.
bx16soupapes
Posts: 18 Joined: Fri Jan 29, 2010 10:00 pm
Quote
0
Post
by bx16soupapes » Sun Feb 28, 2010 3:16 pm
hi i have a instrument cluster 16 valve if you want
